Newbie Question, cannot get Rigid Body property to change while playing timeline
Posted By tjharding 8 Years Ago
Newbie Question, cannot get Rigid Body property to change while...
tjharding
tjharding
Senior Member (263 reputation)Senior Member (263 reputation)Senior Member (263 reputation)Senior Member (263 reputation)Senior Member (263 reputation)Senior Member (263 reputation)Senior Member (263 reputation)Senior Member (263 reputation)Senior Member (263 reputation)
Last Active: 7 Years Ago
Posts: 10, Visits: 66
I'm trying to do this tutorial here useing Iclone 7.1 (not trial) >>   https://youtu.be/9fa7ci0qSX8
I have been stuck for more than an hour trying to get the delayed transition to Rigid Body (Dynamic) to work.
It says in the timeline that it changes from Frozen to Dynamic ... but when the animation generates the object always stays frozen,
unless I stop playing the timeline and then start playing it again, but it is supposed to change on its own while playing.
Anyone know why this is not behaving as shown in the tutorial video ?
Thank you
Threaded View
Threaded View
Forum Post Newbie Question, cannot get Rigid Body property to change while... By tjharding ( 8 Years Ago )
Forum Post Make sure that you are setting the the initial state at frame 1. With... By Rampa ( 8 Years Ago )
Forum Post Thank you for the reply, but yes, I have been doing both of those... By tjharding ( 8 Years Ago )
Forum Post (I tried posting a reply to this thread yesterday, but it seems to... By tjharding ( 8 Years Ago )
Forum Post Since nobody seems to have a notion as to why this is not working... By tjharding ( 8 Years Ago )
Forum Post I found a solution. Instead of using static or frozen states, use... By Rampa ( 8 Years Ago )
Forum Post Thank you kindly , I will give that a try right now . =) By tjharding ( 8 Years Ago )
Forum Post A noble effort, but no, it does not achieve the desired result. If I... By tjharding ( 8 Years Ago )
Forum Post It is certainly a bug, because it used to work in IClone 6. But you... By 4u2ges ( 8 Years Ago )
Forum Post Thank you for that confirmation. I will also try your suggestion... By tjharding ( 8 Years Ago )
Forum Post Yes, that is another way handling this. PS Another avatar looked... By 4u2ges ( 8 Years Ago )
Forum Post >> By "the other avatar looked better" ... I think you might... By tjharding ( 8 Years Ago )
Forum Post Yes, she is very nicely done! Like her :blush: By 4u2ges ( 8 Years Ago )
Forum Post Yes, she's very cool ! Changed my avatar back. Thank you again for... By tjharding ( 8 Years Ago )
Forum Post FT entry for that: Quick test:... By 4u2ges ( 8 Years Ago )
Forum Post Darn! Seems to only work with gravity. By Rampa ( 8 Years Ago )
Forum Post Thank you both very much for investigating this ! By tjharding ( 8 Years Ago )
