OFFICIAL 3DXchange 7.1 Issues Thread
Posted By Peter (RL) 9 Years Ago
WillFl
WillFl
Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)
Last Active: 8 Years Ago
Posts: 38, Visits: 161
WillFl (12/20/2017)
bcmorris (11/25/2017)
@ WillFl
Did you get everything working after following my steps? You should be able to click the apply button after you characterize with the custom profile.
Yes, your work around works, what I also did first was go back to 3DXchange 6.54 and use the characterization there because it still seems to work.  I am looking forward to a fix for 3DXchange 7.1 so it works right the first time..
thanks for your suggestion
3DXchange 7.2 the new patch that came out today has fixed this issue. Although it has introduced a new issue in the Expression editor where it adds unwanted custom face puppet animation to all the custom groups, which makes the characters not work with talk data from Crazy talk character ..
WillFl
WillFl
@ WillFl
Jasonxx
Jasonxx
Veteran Member (617 reputation)Veteran Member (617 reputation)Veteran Member (617 reputation)Veteran Member (617 reputation)Veteran Member (617 reputation)Veteran Member (617 reputation)Veteran Member (617 reputation)Veteran Member (617 reputation)Veteran Member (617 reputation)
Posts: 25, Visits: 195
Will try these out now. Thank you! :)
Posts: 9.2K, Visits: 22.1K
As Gerry says, although IMX it's almost never a polygon issue but rather a texture size one (which is to say you can easily import millions of polygons, but if your textures are 4K you will have problems).
Check your textures first and resize accordingly and see if that then works.
Posts: 5.7K, Visits: 26.5K
Jasonxx (12/10/2017)
I am having a strange issue where, 3dxchange would just completely freeze up upon import of a model. I tried doing different formats but it has then gives me a size warning and suggest I go change the size in another software. Are there any solutions to the freeze up and or size limitations.
3DXchange is still a 32 Bit App, and as such can hang when trying to open large files. These files can either have a high poly count, high resolution texture maps, or a combination of both. One workaround is to break the model down into smaller items, with lower res textures, export each piece and then "reassemble" them in iClone.
Jasonxx
Jasonxx
inash
inash
Posts: 46, Visits: 775
I just tried it. Thanks bcmorris!!
___________________________________________
Graphic Designer / Video Editor / Sound Engineer
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-4930K 3.4 GHZ / MB: ASUS Sabertooth X79 /  RAM: 32GB G-SKILL RIPJAW / HD: 2TB+2TB+3TB  /  SSD: 256 Samsung 860 EVO & 128 Samsung 860 EVO/
GPU: GTX 1080 Ti 11GB / COOLER : CORSAIR H75 Liquid Cooler
bcmorris
bcmorris
Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)
Last Active: 6 Years Ago
Posts: 7, Visits: 111
@ WillFl
WillFl
WillFl
bcmorris (11/17/2017)
Mixamo FBX Convert to Non-Standard not working for me after updating!
After installing the 7. 1 update the Mixamo Animation - Convert to Non-Standard (Characterization) no longer works at all. It was working in 7.02 (after switching the Presets) but in 7.1 the exact same FBX will not convert. I also tried loading in the "Maya Human-IK_Mixamo01" Characterization profile (and all the others) but it gives an error stating that there are incompatible bones so the character will not be activated.
See the Issue report on the Feedback Tracker here.
This is really annoying as I updated to get access to the Iclone Curve Editor plug-in and didn't even need to update 3DXchange. Can I rollback 3dXchange to 7.02, keep Iclone at 7.1 and maintain the "send to functions?
+1
I am experiencing the same exact problem. Plus Appy to iClone is not working
bcmorris
bcmorris
Okay...I was able to map the imported Mixamo FBX bones manually and then "convert to non-standard" character, but all the animations are broke. This includes the previews in the Character setup area and the animations loaded in with the FBX. 3dXchange keeps the animation set to 1 frame after leaving the Character setup area.
But...I found a workaround. I saved my manual bone-map characterization profile out, started a new import scene, re-imported the Mixamo FBX, loaded my saved characterization profile and everything is working. Strange??
