Finger Tips joint weights messed up on FBX to C4D
Posted By supafraud 8 Years Ago
UrbanCat68
UrbanCat68
New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)
Posts: 4, Visits: 239
Solved it!
Open up your FBX file in Cinema 4D. Go to Frame Zero.OpenUpHierarchy of bones on your model and locate Fingertips bones.(Not fL_Finger4Nub)
Turn off skin On your CC_Base_Body.  Click Weight expression tag on CC_Base_Body. Reset bind pose. Now both skin and bones should be in the T position. Go to your bone hierarchy select fingertip bones eg. L_Finger22 go to Coordinates rotation HPB And zero them all. Bones should then correct themselves with in the skin. Once you have done this for all fingers Go back to weight tag set bind pose and turn on skin. All should then be well.
Have fun :D
76% of original size (was 664x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/f2b6528a-30e4-4aac-b18a-8c5b.jpg
UrbanCat68
UrbanCat68
Hi there, I've got the same problem. I have just been putting IClone7 through its paces and every time I import an FBX file to C4d19 the fingers tips get deformed. If you unbind the skin it jumps back about 5mm on the Z axis and deformations disappear. I tried numerous times until the trial exports ran out. Didn't even get the chance to test trial exports from iclone7 in Alembic format.
Apart from that, the animation was running sweet inside cinema 4D19. So close, yet so far...
supafraud
supafraud
Senior Member (394 reputation)Senior Member (394 reputation)Senior Member (394 reputation)Senior Member (394 reputation)Senior Member (394 reputation)Senior Member (394 reputation)Senior Member (394 reputation)Senior Member (394 reputation)Senior Member (394 reputation)
Last Active: 8 Years Ago
Posts: 2, Visits: 5
Hello, I have a problem when exporting from iClone to C4D using FBX (the C4D preset). It seems the finger tips are not weighter correctly and look mangled. Is there a work around for this?
