Tracking FPS really low!
Posted By jairo.assis 9 Years Ago
Jfrog
Jfrog
Posts: 702, Visits: 4.7K
I don't have any problem reaching 90 fps with my Brio.  But I have many windows and a lots of lights.  To be able to track at night, I would  have to add some overhead lights when there is no more light from outside because bad lighting conditions is one of the main reason for average FPS.
Horror Stories in VR
Immersive Sound VR
jairo.assis
jairo.assis
Senior Member (261 reputation)Senior Member (261 reputation)Senior Member (261 reputation)Senior Member (261 reputation)Senior Member (261 reputation)Senior Member (261 reputation)Senior Member (261 reputation)Senior Member (261 reputation)Senior Member (261 reputation)
Last Active: 8 Years Ago
Posts: 7, Visits: 42
Hi Jfrog, thanks for the reply. When you say that you can get 90FPS, are you talking about the camera's FPS or Tracking FPS? The face ware capture windows reports both. My camera's FPS is fine. It's the tracking FPS that is low. And keeps getting lower as time goes on.
I tried this with a couple of cameras. I left the application running overnight, and in the morning my tracking FPS was down to 1 FPS. I think that the Faceware code doesn't dispose of previous data. So the longer you record, the lower your FPS becomes. I can't say it for sure though.
Posts: 9.2K, Visits: 22.1K
Again I would ask the OP as well as you, JFrog, whether you've turned off low-light compensation.  Turning this off *should* allow you both high FPS as well as not needing as much light.
It's a bit counterintuitive, but the low-light mechanism (available only through the Logitech gaming system -- it's on by default on these facecams and cannot be turned off with the Logitech facecam software) actually makes things worse in terms of light needed for capture.  WIth only one rather ill-positioned room light, I'm able to easily get 60fps with this turned off -- with it on the lighting is much more even but I can't get more than 30, if that.  And it's particularly important NOT to have light coming from behind you, JFrog, so your room might not be set up right (I'm not knocking you getting 90fps, only that you might be able to get it at night with a better setup).
I'd love to know if the OP turned this off and got better captures.  I don't see any dropoff as he mentions, so either his hardware is bad or perhaps the demo is crippled further.
Jfrog
Jfrog
In my case, no I didn't not turn this off, In fact I have no idea where to turn that low-light compensation feature off.   ;)
I will try to turn it off at night to see the difference, if I can find where the feature  is located.
Immersive Sound VR
As I said, you will need the Logitech Gaming Software to do this.  Download from Logitech's site and install.  It will see your webcam, and you can click and go to "Advanced" settings where you can turn it off.
I have to do this each and every time (so it's a PITA) but it works a treat.  Pity there's no way to set this as a default, though (a LOT of folks have complained to Logitech about this).
jairo.assis
jairo.assis
Yeah, it shouldn't be my computer. It's a fairly beefy computer.
Intel i7-5820k (water cooled 6 core running at 4.3Ghz),
64GB of DDR4 RAM,
512 SSD Drive
nVidia GTX 1080
I will download the gaming app tonight when I get back to town and let you guys know. :)
Jfrog
Jfrog
I will definitely download the software. Thank you Kellytoons!
Both!   please see attached picture
https://forum.reallusion.com/uploads/images/cc244182-bfb0-4ec0-bf38-f276.jpg
Immersive Sound VR
Rockoloco666
Rockoloco666
Group: Banned Members
Last Active: 6 Years Ago
Posts: 762, Visits: 2.0K
Another thing to try is updating your usb controller drivers if possible, and try connecting the camera to a different usb port,preferably one that isn't shared with anything else, if using a desktop, try connecting it to one of the ports in the back, just to rule out possible hardware related issues or driver issues
Jfrog (9/29/2017)
I will. Thank you Kellytoons!
Cool that you're getting that rate with so much light coming from behind you.  That's usually a big issue, so the Brio is definitely performing well there.
I'll be curious to see how your nighttime performance goes once you turn off low-light.
Jfrog
Jfrog
Yes me too. Tonight isn't the best time to try it, but I will keep you updated.
Thank you
Immersive Sound VR
