Calibration problem
Posted By oldblock 2 Years Ago
oldblock
oldblock
Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)
Last Active: 5 Months Ago
Posts: 13, Visits: 47
I'm working on a G3 character (Ted), the calibration function presents a window with  Body and Face choices. The Body part is blank and the Face part has six functions and clicking them makes my G3 character perform but there is no way to install this function into my character.
Is something faulty or is this a plugin that has to be purchased? How do I fix?
garylearntech
garylearntech
Veteran Member (823 reputation)Veteran Member (823 reputation)Veteran Member (823 reputation)Veteran Member (823 reputation)Veteran Member (823 reputation)Veteran Member (823 reputation)Veteran Member (823 reputation)Veteran Member (823 reputation)Veteran Member (823 reputation)
Posts: 96, Visits: 1.5K
I was curious about this "new" option too, which I didn't recall seeing previously with the Pro version before I recently upgraded to Pipeline.  I rummaged about in the online manual and it seems that you only get Face Motion calibration for G3 characters, so what you're seeing is correct.  G1/G2 characters are the ones that can also benefit from Body Motion calibration.  Scroll down to section 3 here for the distinction.
There's a bit more information about G3 facial calibration in this page: Creating a Custom G3 Head (New for v3).
"After a G3 head is applied, you can use the calibration to view if the motion and expression is ideal, or if further adjustments are required."
You're not experiencing faulty behaviour.  This is a design aid to allow you to test your character – it's not an alternative method for applying animations.  There is no additional plugin required and nothing further to purchase for calibration functionality.
Hope this helps?
CrazyTalk Animator 3 Pipeline (always the current production version, unless otherwise stated)
macOS High Sierra (10.13.6)
Signature data last updated  2018-10-06
