eternityblue
eternityblue
Last Active: 8 Months Ago
Visits: 2.7K
I'm having the hardest time figuring out how to use a custom RGB mask with CC 2.0. What substance do I use? It looks like the instructions here are out of date: http://manual.reallusion.com/Character_Creator_2/ENU/2.0/default.htmlIf I select G6_Cloth.ccTexture, and activate the Appearance Editor, and make sure the Input Maps/Diagnostic section is set to Mode: RGB Mask, I don't see anywhere that I can load a map. I have the Substance Super Tools, so I can use the RGB Map if I set it up within iClone, but how about CC?
My system: i7 3770 Gtx1060 6GB
Last Active: 4 Months Ago
Posts: 5.7K,
With PBR materials you need to load the RGB mask in the "Color ID" slot in the Mesh Data section. You can read more about it here and here from the CC 2 Manual. If you are not using PBR materials then the slot for the RGB Mask is in the "Input Maps/Input Maps" tab:  This time it is named RGB Mask:  Hope this helps some. :)
eternityblue
eternityblue
Visits: 2.7K
Thanks, but I don't get any material slots when I enable 'Use Inputs' in the Mesh Data panel, This is using the CC_PBR_Cloth_V1_3MAT.ccTexture substance. I'm thinking my install might be messed up somehow.
eternityblue
eternityblue
Visits: 2.7K
This is true for the Input Maps for PBR or Traditional. I'm downloading and installing the Essential Morphs and Skin pack again, I am not sure if that is the issue, I will report back.
eternityblue
eternityblue
Visits: 2.7K
OK, that didn't work. I also had CC 1 and CC 2 Beta installed, I have scrubbed my system of all these and now am going to reinstall CC 2. I hope that's it.
eternityblue
eternityblue
Visits: 2.7K
And a re-install didn't work either. I guess I'll submit a support ticket.
eternityblue
eternityblue
Visits: 2.7K
And I reinstalled to the default location instead of an external drive, no luck. I looked in the Windows registry for anything that would change paths that CC may use for substances and saw nothing. I submitted a ticket, but if anyone has any clue about this behavior, please let me know. This is very frustrating.
eternityblue
eternityblue
Visits: 2.7K
eternityblue
eternityblue
Visits: 2.7K
Does anyone know how you can completely remove CC settings? I am thinking some path somewhere or some setting with something is screwy. Or is there something I need to buy extra to unlock this feature?
eternityblue
eternityblue
Visits: 2.7K
OK, I just realized that I need to own the Essential clothes pack to use RGB masks, I wish this were mentioned in the manual. My issue isn't fixed, and I can't say I'm pleased about this, but I'll close this now. It seems to do any little thing in iClone costs me an additional $150. Thanks but no thanks, I'll just create stuff in Substance Designer.
