Changing camera views
Posted By Epluribusunum56 8 Years Ago
Epluribusunum56
Epluribusunum56
Veteran Member (841 reputation)Veteran Member (841 reputation)Veteran Member (841 reputation)Veteran Member (841 reputation)Veteran Member (841 reputation)Veteran Member (841 reputation)Veteran Member (841 reputation)Veteran Member (841 reputation)Veteran Member (841 reputation)
Last Active: 8 Years Ago
Posts: 45, Visits: 165
Hey guys and gals,
I have been working on using different cameras all day, but have a problem.  I am able to add as many cameras as  I want and move them about, even attaching cameras to dummy props and paths to follow the action, but what I cannot do is go from one camera to another during the action.  Every time I try to change between cameras, the entire script changes to that camera's view.  I am getting the impression that you can only use one camera at a time, render that portion, then use another camera; is that right?  Initially, I was going to set up a number of cameras with each at a different location and switch between them as the performance played out.  I know that you can use any camera and animate it, but I wanted to just switch between cameras that are already set up for the different views.  The only way I can see to do that right now is render each camera view and then put them together in a video editor to get the effect of different camera angles as the performance plays out.  I want to jump in and out from up close facial views to distant views.  Is there a way to get multiple camera views without rendering and using a video editor to see the different camera views in one performance?
Mark
