How to import mocap animations into 3DExchange and use for human
Posted By dasjlm 9 Years Ago
dasjlm
dasjlm
Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)
Posts: 12, Visits: 193
I can open an FBX mocap file and it goes into 3DExchange but I can't convert to human as it thinks it is a prop.  If I open the FBX modle in Unity it is configured as Human so not sure why that doesn't work.  Any tipes?
Thanks in advance.
John
Posts: 15.8K, Visits: 31.4K
FBX is always imported as prop. To convert, make sure your character's root is selected.
In the Modify panel on the right, there is a section called Character (press "N" to go there).
There should be an option Convert to Non-standard.
Click that and you should then be able to start to process to convert from prop to character.
Here is a tutorial on how that is done:
dasjlm
dasjlm
I tried that.  The panel on right shows the node selected is the RootNode but the Character panel is still greyed out. I suspect it might be because I'm just using the Mocap animation FBX as installed from the MOCAP lib.  I will do a bit of checking to see what's missing in it.
John
dasjlm
dasjlm
An install/reinstall fixed this problem.
