madisonw
madisonw
Last Active: 9 Years Ago
Visits: 15
I am trying to export a character animation with a transparent background to use in my training courses. I have tried several different work-arounds to try to get a transparent background, but haven't had any luck. Here's what I have tried so far: - Export as AVI file with green screen, remove in video editing software.
- Export as popVideo file, remove background.
- Export as PNG sequence.
All of these options export with a background which I am able to remove with secondary software (popVideo or other video editing program), but when I render and export the video out of the secondary program it always has a background again. Any suggestions would be greatly appreciated! Thank you!
RicksWorks
RicksWorks
Last Active: 7 Years Ago
Visits: 413
This is a major function that I thought for sure would be a standard export option by now. Please Dev's, give us transparent bg export.
Rick Owens
propose
propose
Visits: 1.2K
Have you tried Hitfilm? Works for me!
RicksWorks
RicksWorks
Visits: 413
I tried HitFilm a long time ago, but I have a subscription to Adobe CC.
Rick Owens
garylearntech
garylearntech
Visits: 2.3K
Well, I've done it successfully on my Mac version, so I'd be astonished if you can't do it on your Windows version. (From memory, I had to choose the "Apple ProRes 4444" video codec.) The output formats are different on the Mac version, but the one common feature I wonder if you've missed – I missed it initially – is to turn off the Render Hidden Objects checkbox. (I had been using a placeholder for positional work, which I merely hid once I was finished. It was still exported.) In case you've missed it and it might help you, the manual has this to say about exporting.
--- Cartoon Animator 4 Pipeline (always the current production version, unless otherwise stated) Mac mini M1, macOS Big Sur (11.6.5) Signature data last updated 2022-05-15
Posts: 23.1K,
Visits: 36.6K
madisonw (7/20/2017)
All of these options export with a background which I am able to remove with secondary software (popVideo or other video editing program), but when I render and export the video out of the secondary program it always has a background again. Any suggestions would be greatly appreciated! Thank you! I don't really understand the problem you are having. If you are on a PC you can export Sequence Image PNG and you will get a transparent background. Obviously if you include a background in your scene then this will be rendered too. Try with a new project and just add a character. Then give the character an animation and render to Sequence Image PNG. You will find all the sequence images have a transparent background.
shayeryan
shayeryan
Last Active: 8 Years Ago
Visits: 29
I'm having the same problem and these are my settings.
Rendering to PNG, AVI, hidden objects unchecked. The only thing in my scene is a single character according to the the scene manager but I still get a grey background every time I render.
Why?
kylelee
kylelee
Visits: 4.2K
Hi, You can refer this video to remove your background. Crazytalk animator & After EffectsAnother way is export sequence PNG Images in the external video editor.
shayeryan
shayeryan
Visits: 29
Thanks for the reply but that didn't really solve anything. That video is so fast I can hardly tell what's going on. At about min 3:30 he has the MOV file in after effects and using a plugin called key light that does something to the background and makes it go away. Now what?? Also, I am using an external editor, Premiere. Here is how it looks when I drop the video into the timeline.
theschemer
theschemer
Posts: 1.4K,
Visits: 2.9K
