Tutorial: Multi-Stage Transitional Morphs using iClone 7 and iClone 6
Posted By Lord Ashes 8 Years Ago
Rated 3.7 stars based on 3 votes.
Lord Ashes
Lord Ashes
Posts: 1.3K, Visits: 1.6K
Previously I did a tutorial on multi-stage transitional morphs (https://youtu.be/xYcOE7hY8QI) were I identified the difficulty of making multi-stage morphs because each successive morph stage needs to subtract out the previous morph stages. This means instead of just creating meshes which match the various stage of the morph, the user needs to create less intuitive delta morphs.
This applies to morph objects in iClone 6 (implemented using Dummy Bone and Face Expressions) and iClone 7 (implemented using the Morph Creator and Animator).
This tutorial video demonstrates the problem showing what a improperly executed multi-stage morph will look like (i.e. one that uses the morph meshes directly) side by side with what a properly executed multi-stage will look like (i.e. one that uses delta morphs). At the end of the video, I offer a possible solution for easily creating the necessary delta morph files for implementing your multi-stage morphs properly.
(EDIT1: Updated links to version 1.1 which compensates for OBJ files which do not specify a "g" (group) entry)
(EDIT2: Updated links to version 1.1 of the binaries. Previous link was still pointing to the old binaries)
(EDIT3: New links to source code and binaries)
As the video says, if you want to use the MorphBuilder program (written by Lord Ashes himself) to simplify your multi-stage morph creation, you have two options:
1. Trust Lord Ashes and download the windows binaries from http://www.mediafire.com/?e76zykp98im7y
or
2. Don't trust Lord Ashes (no offense taken) and download the source code from http://www.mediafire.com/?e76zykp98im7y
(The source code is a Visual Studio 2015 project which can be compiled with any edition of Visual Studio including the free Community edition).
Threaded View
Threaded View
Forum Post Tutorial: Multi-Stage Transitional Morphs using iClone 7 and iClone 6 By Lord Ashes ( 8 Years Ago )
Forum Post Very interesting. I got 2 questions though: 1. Is it possible to have... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (7/15/2017)[/b]1. Is it possible to have the same... By Lord Ashes ( 8 Years Ago )
Forum Post Hmm...The forum keeps telling me that I have exceeded my space, when I... By Lord Ashes ( 8 Years Ago )
Forum Post BTW, just a heads up. The program is a quick implementation so it does... By Lord Ashes ( 8 Years Ago )
Forum Post I must be doing something wrong. I have an original and 3 consecutive... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (7/15/2017)[/b][hr]I must be doing something wrong.... By but0fc0ursee ( 8 Years Ago )
Forum Post @ Lord Ashes As oppose to complex .obj I just tried a simple cube in... By 4u2ges ( 8 Years Ago )
Forum Post It's a simple code. One or more of the parameters are not met. You're... By but0fc0ursee ( 8 Years Ago )
Forum Post Swoop, really, you have no idea what you are talking about :) You are... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (7/15/2017)[/b][hr]...you have no idea what you are... By but0fc0ursee ( 8 Years Ago )
Forum Post [quote][b]but0fc0ursee[/b]I'd never use that... I use the following... By Lord Ashes ( 8 Years Ago )
Forum Post OK. It seems that I made an assumption which does not seem to be... By Lord Ashes ( 8 Years Ago )
Forum Post [quote][b]but0fc0ursee (7/15/2017)[/b]Is the source and delta a... By Lord Ashes ( 8 Years Ago )
Forum Post [quote][b]4u2ges (7/15/2017)[/b][hr]I must be doing something wrong.... By Lord Ashes ( 8 Years Ago )
Forum Post Please see my PM Lord Ashes. By 4u2ges ( 8 Years Ago )
Forum Post This is awesome! I finally did compile your project (have not done... By 4u2ges ( 8 Years Ago )
Forum Post I am glad we got it working. If other people experience trouble with... By Lord Ashes ( 8 Years Ago )
Forum Post Thanks again Lord for your efforts! By 4u2ges ( 8 Years Ago )
Forum Post It seems that the link have expired for free access. If anyone is... By Lord Ashes ( 7 Years Ago )
Forum Post Re-posted the source code and binaries on a different hosting website.... By Lord Ashes ( 7 Years Ago )
