meli235
meli235
Visits: 6
Is there a way to export a video (avatar) with a transparent background in Crazytalk 8?
AyoungBlueSky
AyoungBlueSky
Visits: 2
I was just about to ask the same question. The main use of CT8 for me would be to superimpose my heads on to existing videos, to provide narratives. Obviously, I would need a transparent / green screen background to achieve this.
visionsforyou
visionsforyou
Visits: 33
Yes there is , you can make an Alpha channel for your avatar. under file go to background setting. go to background setting for a pop up window. Select actor only. Then export your actor.
Once that is down,you can import in to program like After Effects or premier Pro.
no need for green screen.
deweymcg
deweymcg
Visits: 7
I just purchased the latest version of Crazy Talk 8 Pro. I do not see Background Settings under file or on my tool bar. The only place is under Content Manager and there is no setting for Actor Only.. Did they remove this feature?
vepop
Last Active: 9 hours ago
Visits: 7.2K
I see that some queries are left unanswered.
Last Active: 8 hours ago
Posts: 7.6K,
Visits: 16.5K
This forum is far more active on iClone issues -- and while I have CT I can't say I use it much (or at all, except to make 3D heads). Put a trouble ticket in for RL.
Alienware Aurora R7, Win 10, i7-8700k, 4.7GHz CPU, 32GB RAM, GTX Titan XP (12GB), Samsung 960 Pro 2TB M-2 SSD, TB+ Disk space Mike "ex-genius" Kelley
JimmyB7
JimmyB7
Visits: 3.1K
I think it depends upon if you are creating a 2D Actor or 3D Actor. Here is what the Manual says:
I use green background for 3D Actors.
CyberpowerPC, 64 GB Ram, 64bit Windows 10 Pro, Intel Core i9-10980XE 18 Core CPU, ASUS TUF X299 Mark 1 Motherboard, ROG-STRIX-RTX2080TI-O11G-GAMING graphics card, Toshiba 3TB hard drive, 3 x Seagate 3TB hard drives, RAGNAROK 801 Full Tower, LEPA G1600 1600W power supply, Killer WI-FI 6, ASUS PA329Q 32" 4K/UHD IPS Monitor.
Last Active: 39 minutes ago
Posts: 18.4K,
Visits: 28.3K
deweymcg (8/20/2017) I just purchased the latest version of Crazy Talk 8 Pro. I do not see Background Settings under file or on my tool bar. The only place is under Content Manager and there is no setting for Actor Only.. Did they remove this feature?When you create a new project it will by default have no background and just display the actor. In the Windows version you can then animate your actor and then render to Sequence Image PNG format where it will maintain a transparent background.
hpotter12876
hpotter12876
Visits: 137
Go into atmosphere settings(under the menu bar at the top) and deactivate the image (uncheck) and export under ProRes4444.
3 Years Ago by
hpotter12876
