Improvements to Speedtree Distribution -Paint controls and a Plant Room function
Posted By will2power71 7 Years Ago
Improvements to Speedtree Distribution -Paint controls and a Plant...
will2power71
will2power71
Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)
Last Active: 9 hours ago
Posts: 385, Visits: 2.7K
I put this in as a feature request for iClone 6, and I'm repeating this for iClone 7.
The speed trees have got to be the single most useful plugin for scene creation in iClone, but planting the trees is tedious at best. This is because the function for distributing trees will only work on one species at a time and distributing it by a square is about the most inefficient means of placing trees. It only works properly if you have a square environment.
It would be far more effective to have a paint mode much like the terrain tool, or allow you to have a placement map for the given scene. You can use a grey scale map to designate where the trees should be. This allows you to quickly distribute trees in the proper area without having to constantly click and move all over the terrain to plant one species of tree, then switch to another species and repeat the process.
Instead, the user should have a plant tab where you can click and drag the species into a queue, with a separation between grass, shrubs, trees and finally rocks/boulders. You can then set the options and hit the place button. The user could then have a complete forest planted complete with paths where there are no plants/trees/grass grow. You can paint the map in Photoshop, or use a built in brush for each plant level. You make a pass for grass, then one for trees and so on. Make it so you can tweak and repeat each section without influencing the others --this way if you don't like the way the rocks are done, you can redo it without touching the trees or grass. Allow the user to paint on geometry that has been brought in so they can distribute the trees on their own custom terrains or they can use the iclone native terrains.
I've also submitted this in the feedback tracker. You can view it here
rampart
rampart
Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)
Last Active: 6 Years Ago
Posts: 1.4K, Visits: 5.1K
Getting alot of trees into scenes is tedious.  There is a problem because the more trees the more memory affected.
I still have the older version of the landscapte design package.
When the new trees package came out with IC6 I had learned my lessons on trees.
One thing I learned was to use 2d images of trees for backgrounds.
I have a bunch of 2d clumps of trees I exported from Daz3d.
https://www.daz3d.com/treescapes-backdrops
Next I learned to only make my scenes with small groups of trees in small scenes.
That is, when I wanted viewers discriminate on what types of trees.
There are textures you can use for views looking down on trees you can use for flyovers
Here are some ideas from Daz3d that may interest you.
I don't have this content, but it may work I have been thinking about trying them.  I'm waiting on a sale.
The files are *.duf which you should be able to export into 3dxchange and set as props.
Then pass them through to Iclone.
https://www.daz3d.com/em-aspen-billboards-and-forests
https://www.daz3d.com/em-multires-aspen-trees
7 Years Ago by rampart
