One thing would make my workflow so much easier
Posted By BlueMetalVictory 16 Years Ago
BlueMetalVictory
BlueMetalVictory
Posted 16 Years Ago
Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)
Posts: 20, Visits: 163
I have one suggestion - allow the flv export format to allow the addition of an alpha channel, and also to all resolutions.
Forgive me if this is already possible - I just don't see how.
At the moment I need to export as avi - to get the desired resolution, and then using a blue or green background, I import that into Premier or After effects and key out the background. This can be very difficult if the clone is wearing reflective safety equipment - as the key tends to pick up the bg colour at the edge of the glow. I then need to export the file to flv for use in Flash eLearning products.
It would make production so much quicker if I could export straight from iClone to any resolution, and included the alpha channel in the flv. That way it would be iClone direct to Flash - and I wouldn't have to manipulate the keying effect on a 2D movie.
Regards,
Mike
