Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
Here is a tutorial, brought to you by Lord Ashes' Warehouse, on how to achieve Texture Map Swapping on Keyed Frames even though iClone does not support keyed texture changes.
Hope you find this helpful...
7 Years Ago by
Lord Ashes
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
Sample content created using this technique...
Zeronimo
Zeronimo
Last Active: 43 minutes ago
Visits: 19.1K
@Lord Ashes : Good find. Thank you for sharing
fmccann
fmccann
Visits: 3.3K
@Lord Ashes : WOW!, that is a very clever idea. Thank you, 5 stars+
7 Years Ago by
fmccann
Delerna
Delerna
Posts: 1.5K,
Visits: 14.8K
Saw this yesterday and meant to watch it last night but forgot about it. Must must must remember to watch it tonight. I'm sure its going to help me with what I am currently working on Edit Changed my mind and watched it at lunch time. That's pretty obvious but not something I had thought about until now. Thanks for demonstrating the method
i7-3770 3.4GHz CPU 16 GB Ram GeForce GTX1080 TI 11GB Windows 10 Pro 64bit
7 Years Ago by
Delerna
CtrlZ
Visits: 4.4K
Thank you!In the past I would have renderd two identical scenes (swaping out the textures in the second) and spliced them in my editor! this will save a consideral amout of time and I am wondering if you could the same tecnique on the bump and displasement channels for bullet holes and deep cuts
Home built liquid cooled AMD Ryzen 7 1800X cpu (8 core 16 thread) 4.0GHz, rtx 3090, ASUS Crosshair VI Hero motherboard, 64 GB RAM, 500 GB SSD (Samsung 850 EVO) 6 TB HD's 4K monitor.
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
I do this another way I save my textures as avi files using virtualdub and loop the first then the second iClone will keyframe avi changes as in adding a new file along timeline
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
well actually any video even mp4 and WMV and iClone 5 does it too
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
CrtlZ (6/1/2017) Thank you! In the past I would have renderd two identical scenes (swaping out the textures in the second) and spliced them in my editor! Yes. This is what I would have done in the past too but I am trying to eliminate the need for re-processing as much as possible, so I came up with this technique.
CrtlZ (6/1/2017) I am wondering if you could the same tecnique on the bump and displasement channels for bullet holes and deep cuts I have not tried it but by the title of the timeline track, I believe that this technique should be usable for any of the Texture Settings including Diffuse, Opacity, Bump, Specular, Glow, Reflection, Blend and Displacement. The only down side of this technique is that if you are doing very subtle transformations the texture size can get very big (because you need many transition textures).
7 Years Ago by
Lord Ashes
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
wendyluvscatz (6/1/2017) I do this another way I save my textures as avi files using virtualdub and loop the first then the second iClone will keyframe avi changes as in adding a new file along timelineNice alternative solution
