My Experiance with Reallusion CrazyTalk Pro 5.1
Hi I'm just bought crazytalk pro 5.1 downloded it and it would crash and freeze i couldn't get it to work right at all. I was going to return it then i thought maybie ill try it on my other pc and see if it works and sure enough it worked fine on my other pc. So i thought well this is an older pc so i thought maybie if i ran the compatability wizard on xp? hmm' so i did, I ran it like it was runing windows 95 and boom it started working right. go figure It worked for me try the compatability wizard I have xp pro operating system and xp home on my wifes pc.
Im a happy camper now wtg me! :D
I tryed reallusion support with no success this is what they said.
They made it sound like it was my pc that was at fault. After completing most of what was asked below it still didn't work right
Thank you for contacting Reallusion.
The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space. There are various factors, which cause Kernel32.dll crash. The following conditions can cause Kernel32.dll error messages:
1. File allocation damage.
Please try to full uninstall and reinstall the program.
2. Bad or outdated drivers, especially video drivers:
Check with your card manufacturer for an updated set of drivers. Video drivers are updated constantly, it pays to have the latest release, especially if you find yourself having problems with Internet Explorer.
3. Conflicting with TSR or other running program
You need to close whole terminate and stay resident programs. If you are running the other applications at the same time, please stop them first.
4. Non-existent or broken Temp folder
You can delete temp files via the following steps.
(a) Click Start, and then click Run.
(b) In the Open box, type %Temp%, and then click OK .
(c) Delete all of them.
(d) Go to C:\Windows\Temp
(e) Delete all of them.
5. Incorrectly installed printer drivers or HP Jetadmin drivers
Please try to full remove your printer drivers.
6. Computer Viruses
Due to computer viruses are capable of tampering with the system settings / memory, it is possible for a computer virus to generate a error. If you are currently running a virus protection program on your computer ensure it has the latest updated patch or .dat file.
7. Graphic acceleration set too high:
Select Control Panel > System, then select the Performance tab, click the Graphics button. Turn down Hardware acceleration by moving the slider a notch to the left, reboot, try again.
8. Low disk space.
Please be aware the disk space should be enough.
9. More on the possible causes:
1) Damaged or incorrect version of the Kernel32.dll file.
2) Damaged registry.
3) Hardware, hot CPU, over clocking, broken power supply, RF noise, ground bounce, or bad hard disk controller
4) Third-party software that is damaged or incorrectly installed .
5) Incorrect or damaged hardware driver
6) Incompatible or damaged dynamic link library files
8) Bad memory modules.
9) CPU, bus speed or multiplier overclocking.
If you have any further queries, please do not hesitate to contact us.
Yours sincerely,
Mick
Technical Support
Reallusion Inc.
