Lamias (5/8/2017)
Hey there,
I am thinking of purchasing a PN suit, and I am wondering about the quality of the motions produced with it.
How are you finding it? Did the solution you found work for you?
You will find that the motions created with the suite aren't perfect. You will need to do some cleanup after each take in order to get the best results. However, in comparison to other options available at this time... I would say it is the best thing available. Also, I highly recommend that if/when you purchase your suite you spend the extra $199 for the anti-magnetic case in order to protect your investment. I have heard others complain about neurons not working after a couple of sessions. They are very sensitive and cannot be around most anything you might have that is electronic. I purchased the case and have not had any issues after several sessions. You might also want to check out this video:
Working with Perception Neuron
