michal.tworek
michal.tworek
Last Active: 8 Years Ago
Visits: 50
I think body is selected, but everything is shaded (not active) in "smooth window".
Snarp Farkle
Snarp Farkle
Visits: 3.6K
You have to select the mesh to use the "Auto Smooth" function in 3DxChange, if you have more than one mesh the "Shift Select" all of them.
Last Active: 4 Months Ago
Posts: 5.7K,
Make sure that you have the Body selected in the Scene Tree, and Weld Vertex checked in the Normal tab. You can increase the amount next to the Auto Smooth box.
michal.tworek
michal.tworek
Visits: 50
I already founf this https://www.reallusion.com/iclone/Help/3DXchange4/PRO/Auto_Smoothing_Mesh_Nodes.htm , but here "auto smooth" is not active:  If there is any "smooth" button please let me know. In iClone is "realtime smooth", but it looks to work only in iClone.
Am7add9
Am7add9
Visits: 9.3K
3dxchange has smoothing in the right menu "normal" section i imagine 3 other people will post the same thing, so disregard my post
michal.tworek
michal.tworek
Visits: 50
If there is no option to make it smoother then I have some option: Import OBJ to blender. To see a mesh switch to EDIT MODE.  Look at MESH TOOLS on the left. ADD: subdivide
DEFORM: smooth vertex to see an effect you can switch to object mode and switch between smooth and flat shading (flat is the REAL one):  You may repeat subdividing and smoothing vertex Export to *.OBJ Do you know a way how to do it in iClone?
michal.tworek
michal.tworek
Visits: 50
Well guys, I found nice way: Create character . Open in iClone. press "N" - > adjust pose bones Content Window->Motion->Custom Animation Custom->Motion Press"+" , add name to your new POSE. ____________________________________ Open in 3DXchange Press "N" Load Pose Export OBJ Still don't know how to improve mesh density
michal.tworek
michal.tworek
Visits: 50
Thanks all of you :-) I will try, but I'm happy this is possible. What with quality? I mean mesh density. Is it possible to make it smoother?
Am7add9
Am7add9
Visits: 9.3K
i didn't try that scrubbing through the timeline.:crazy: that is a big time saver, thanks.
Snarp Farkle
Snarp Farkle
Visits: 3.6K
michal.tworek (4/25/2017) Hi all! :-) Can anyone explain me how to export character after editing pose. I want to change pose of my character and print on 3d printer. I thought that maybe setting as default in "edit pose" window is enough, but unfortunatelly no. What with quality? Is there some way to make it smoother? Michal The only way I know of is to load your character in iClone then select to edit your character in 3DxChange. Import an animation and find the pose you are happy with by scrolling through the play head. Then export it as an obj, and then if you load that obj into 3DxChange you'll see that it saved in the pose you had at the time you exported the obj. I don't know if 3D printers can use obj files but this is the only way I know of to get a saved character in a selected pose.
