Substance Engine supported version
Posted By saavedraerwin 9 Years Ago
saavedraerwin
saavedraerwin
Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)
Posts: 21, Visits: 193
hi guys,
just want to confirm that character creator 2.0 doesn't support substance engine v6 (sbar files created with substance designer 6). if so, when do you expect to solve. thanks!
cheers,
erwin
Posts: 5.7K, Visits: 26.5K
I haven't had any problems using substances fron SD 6. Could you explain what isn't working for you in a more detailed way?
saavedraerwin
saavedraerwin
hi, i'm testing custom made substances. i can load any other substance. but not even the simplest of them, made in sd6, can be loaded. i did test with some source.allegorithmic ones, which i assume use the latest, although this isn't necessarily a fact. is there a setting i must add in sd6 for cc to be able to load them?https://forum.reallusion.com/uploads/images/208408d4-8b8c-45e4-af65-d448.jpg
https://forum.reallusion.com/uploads/images/8e187278-7040-4747-8012-f9b7.jpg
duchess110
duchess110
Last Active: 6 Years Ago
Posts: 2.0K, Visits: 15.5K
In Designer you need to select publish and save a  sbsar format then CCreator should then read it.
Duchess Designs Store
saavedraerwin
saavedraerwin
hi, yes of course, if you see in the first pic, i already places test.sbar there. it isn't loading. any idea?
saavedraerwin
saavedraerwin
hi, just tested with the same basic sbar but generated using SD5, and it works. so it appears it is a compatibility issue with SD6? please confirm. thanks!
https://forum.reallusion.com/uploads/images/9b8c7815-68d5-4f71-83c7-089c.jpg
Posts: 8.2K, Visits: 26.5K
I think SD 6 has a "compatibility" setting of some sort, so it can export in a v5 format.  I don't have the details at my fingertips (can't run SD on my phone).  That might be worth looking into as an interim solution/workaround.
saavedraerwin
saavedraerwin
hi, thanks for your response! fortunately i have SD5, and it appears to work fine. but i wish to use some of the features found on SD6, which appears not to  be supported (yet). this is what i am trying to confirm. thank you for your suggestion!
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
Hi saavedraerwin, wires, duchess110 and justaviking
We will update the SDK in the coming CC version, which might fix the issue.
saavedraerwin
saavedraerwin
hi miranda, perfect, thanks!
cheers,
