VR 360 Custume Mode Output Size " NOT Editable " - iClone 6.5 Pro
Posted By Space 3D 7 Years Ago
Space 3D
Space 3D
Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)
Posts: 228, Visits: 1.6K
Dear iCloner or RL  ,
Please info or reference for  -----------> How to changes ' Output Size VR 360 Mode " MP4 export.
I use custume mode , but NOT Editable . ( VR 360 )
Populer VR 360 Video is Rasio  ---------->  2 : 1
https://forum.reallusion.com/uploads/images/c33eac6f-1bd3-4c4f-b02a-cc0f.jpg
Last Active: 14 hours ago
Posts: 22.7K, Visits: 35.7K
Hi..
Unfortunately iClone has strict rules about VR360 export. You can adjust Frame Size but not the aspect ratio. This is fixed along with the focal length (12mm).
Last Active: 12 hours ago
Posts: 15.7K, Visits: 30.5K
As Space 3D points out, the aspect ratio should at least be changed to a fixed 2:1. In addition, the user should be able to select a higher resolution than is currently available.
From the YouTube specifications page (emphasis mine):
For the best results, encode your video at a high resolution and according to YouTube's advanced specifications. YouTube currently supports 360° videos with 24, 25, 30, 48, 50, or 60 frames per second. We recommend uploading  360 videos (equirectangular format with a 2:1 aspect ratio) at a resolution of 7168x3584 or higher, up to 8192x4096.
I believe this is in the Feedback Tracker; if not, I will add it.
I seem to remember that in iClone 6.5 Beta the ratio was the correct 2:1, but that has since changed. Currently, you can only select the size according to the standard HD and UHD formats, which have a different aspect ratio which is not correct for 360 video. Should be relatively easy to fix.
JimmyB7
JimmyB7
Posts: 198, Visits: 3.2K
https://www.reallusion.com/FeedBackTracker/Issue/Exporting-Panorama-Videos-with-4096x2048-frame-size-missing
CyberpowerPC, 64 GB Ram, 64bit Windows 10 Pro, Intel Core i9-10980XE 18 Core CPU,  ASUS TUF X299 Mark 1 Motherboard, ROG-STRIX-RTX2080TI-O11G-GAMING graphics card, Toshiba 3TB hard drive, 3 x Seagate 3TB hard drives, RAGNAROK 801 Full Tower, LEPA G1600 1600W power supply, Killer WI-FI 6,  ASUS PA329Q 32" 4K/UHD IPS Monitor.
Thanks, Jimmy. I added a comment and my vote (more votes are needed!).
Jfrog
Jfrog
Posts: 696, Visits: 4.7K
I add my vote too.
Horror Stories in VR
Immersive Sound VR
