Space 3D
Space 3D
Visits: 1.6K
Dear iCloner or RL , Please info or reference for -----------> How to changes ' Output Size VR 360 Mode " MP4 export. I use custume mode , but NOT Editable . ( VR 360 ) Populer VR 360 Video is Rasio ----------> 2 : 1
Posts: 22.6K,
Visits: 35.6K
Hi.. Unfortunately iClone has strict rules about VR360 export. You can adjust Frame Size but not the aspect ratio. This is fixed along with the focal length (12mm).
Last Active: 3 hours ago
Posts: 15.6K,
Visits: 30.3K
As Space 3D points out, the aspect ratio should at least be changed to a fixed 2:1. In addition, the user should be able to select a higher resolution than is currently available. From the YouTube specifications page (emphasis mine): For the best results, encode your video at a high resolution and according to YouTube's advanced specifications. YouTube currently supports 360° videos with 24, 25, 30, 48, 50, or 60 frames per second. We recommend uploading 360 videos ( equirectangular format with a 2:1 aspect ratio) at a resolution of 7168x3584 or higher, up to 8192x4096.
I believe this is in the Feedback Tracker; if not, I will add it.
I seem to remember that in iClone 6.5 Beta the ratio was the correct 2:1, but that has since changed. Currently, you can only select the size according to the standard HD and UHD formats, which have a different aspect ratio which is not correct for 360 video. Should be relatively easy to fix.
JimmyB7
JimmyB7
Visits: 3.2K
https://www.reallusion.com/FeedBackTracker/Issue/Exporting-Panorama-Videos-with-4096x2048-frame-size-missing
CyberpowerPC, 64 GB Ram, 64bit Windows 10 Pro, Intel Core i9-10980XE 18 Core CPU, ASUS TUF X299 Mark 1 Motherboard, ROG-STRIX-RTX2080TI-O11G-GAMING graphics card, Toshiba 3TB hard drive, 3 x Seagate 3TB hard drives, RAGNAROK 801 Full Tower, LEPA G1600 1600W power supply, Killer WI-FI 6, ASUS PA329Q 32" 4K/UHD IPS Monitor.
Posts: 15.6K,
Visits: 30.3K
Thanks, Jimmy. I added a comment and my vote (more votes are needed!).
Visits: 4.7K
I add my vote too.
