Posts: 15.8K,
Visits: 31.4K
I believe dragging and dropping has been the recommended method, at least for the earlier CC versions.
theschemer
theschemer
Posts: 1.4K,
Visits: 2.9K
It seems to work much better dragging and dropping rather than importing them. That's odd but it works so that's a good thing. Thanks, TS
theschemer
theschemer
Posts: 1.4K,
Visits: 2.9K
Snarp, I guess it may be because of Win7 or maybe my Nvidia driver as others have had to roll back their drivers for various reasons, and I also have seen flickering problems here and there even with the gizmo. I can get that particular head to load eventually but it definitely fails more often than not. Seems to work better if I just use the defaults as opposed to "Head Only" when loading it. I will try dragging and dropping and see if that helps. If it is a driver issue maybe the next update will magically fix it or I will manually fix it once I know which driver is the best one to use. I like the guys shirt (or bra) in the last pic. :P Good luck with the magazine. TS
Snarp Farkle
Snarp Farkle
Visits: 3.6K
theschemer (3/29/2017) Thanks for the test. First question, how did you link the 100 heads to the CC2.0? I am still using the Import method. Ans second, I tried it again and it worked, but then I tried the original head I was wanting to use earlier and it fails. Could you try the head named: M_M_002.RLHead
Let me know if that one works for you. Thanks, TS Edit: I tried it again and now it worked. Must have some Gremlins in my pc. I will keep an eye on it and see if it is a minor deal or not. Sorry it took me so long to reply theschemer, been a little busy with the magazine. :ermm:
I was able to load the M_M_002.RLHead to all three standard characters, CC2.0_Standard, CC_Standard_AFP, and CC_Standard_AFPx. My method has always been to drag and drop the RLHeads onto the avatar, I've never used the import option as it seemed to take longer. I also haven't changed any settings and just click the "OK" button on the "RLHead Import Options Tab". I am using Windows 10. [EDIT: I should mention that for the CC2.0 standard avatar I do click the reset button prior to loading the RLHead. I also have saved the AFP avatars in 2.0]
theschemer
theschemer
Posts: 1.4K,
Visits: 2.9K
jollyro (4/2/2017) I installed CC2 on my old system and had to realize, that it wont really work with my 680 TI Card. I can play around with it, start doing some changes, but it mostly just quits working after a few minutes.Mostly it just freezes. I was trying to load in some Heads, but it crashed, when I tried to do so. I assumed, it is my old system. (I7 second generation, 24 gig ram,NVIDIA 680GT 1GB, Win 10 64 bit) I guess I wait until I have a better system and the bugs are all removed from the program. Luckily for me it is just fun on the side, I do not need to make money with it. Just buy a new video card like a Nvidia GTX 1060, 1070 or 1080 and you may be fine. TS
jollyro
jollyro
Visits: 503
theschemer
theschemer
Posts: 1.4K,
Visits: 2.9K
animagic (4/2/2017) There may be a compatibility issue. I don't remember the details but I thought that the AFP characters and heads had a somewhat different architecture as they are not officially RL.
I also thought that CC 2.0 includes the benefits of the AFP heads and that there isn't really a need for them. 3DTest would be the one to ask.I was thinking about that myself so you may be right about that. I just got into the habit of using the AFP avatars. If he doesn't see this thread I will send him a PM. Thanks, TS
Posts: 15.8K,
Visits: 31.4K
There may be a compatibility issue. I don't remember the details but I thought that the AFP characters and heads had a somewhat different architecture as they are not officially RL. I also thought that CC 2.0 includes the benefits of the AFP heads and that there isn't really a need for them. 3DTest would be the one to ask.
theschemer
theschemer
Posts: 1.4K,
Visits: 2.9K
Thanks for the info. I can always use version 1.5 CC for now. TS
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Ièm on Windows 10 with a brand new PC. Nvidia 1070.
