I own both Crazytalk 8 PRO and CTA3 Pipeline - despite the correct
codecs being installed and verified (Windows 7 SP1 PRO 64-bit -- Nvidia GeForce Drivers -latest installed - 32MB RAM - 5TB HDD storage) - these two packages throw this error on export >> "FAIL TO INVOKE CODEC" - Only
codecs that work are: FULL FRAME (uncompressed), DV Video Encoder, MJPEG Compressor - WebM VP8 does NOT work - Xiph.org Theora Encoder does NOT work.
I have attempted to uninstall / install multiple times - still do NOT work - same error msg. -- I have other editing tools (NLE After Effects / Premiere / and various 3rd party video converter softwares << These programs recognize the SAME
codecs and have no problem invoking them. ONLY YOUR SOFTWARE!!!! Both GSPOT and Sherlock Codec Detective list the
codecs / show them installed correctly -- no obvious issues.
I would like a reason for this problem - too often now - Reallusion makes promises for features that simply don't work / are still on the drawing board / coming soon... Either it works as advertised or it doesn't. Before someone from Reallusion says, "Send us your project file - the tests were done with your CANNED mad scientist character for CT8 Pro and G3 - Humans for CTA3 --- obviously something is amiss. The
CODECS work with other softwares NO problem - only YOUR software either refuses to invoke the codec OR crashes the applications.
Need some type of resolution here. Too much money spent for software that doesn't work as advertised or promised!!
