Fixing root animation
Posted By mtakerkart 8 Years Ago
Cary B
Cary B
Posts: 478, Visits: 3.8K
WOW! This is fantastic,thanks so much for sharing this, 3DTest! I add my kudos for all your hard work. And thanks for the update, Rampa.
https://forum.reallusion.com/uploads/images/848c8492-ac67-42c2-9d27-461e.jpg
Walt_R
Walt_R
Last Active: 9 Months Ago
Posts: 516, Visits: 5.0K
Tried it and it works. Fantastically simple. :D Thank you 3DTest.
CtrlZ
CtrlZ
Last Active: 3 days ago
Posts: 328, Visits: 4.5K
Game Changer for me Awesome!
RobertoColombo
RobertoColombo
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.6K, Visits: 3.0K
Unbelievable!
The solution was under our nose for years :laugh:
Thanks a lot for sharing this tutorial !
Cheers
  Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO + 1x2TB Samsung
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the MOTU M4 I/F) / DirectX: 12
Posts: 8.2K, Visits: 62.6K
And another follow up.........
When using motions that start out in different directions (the ones that cause the dreaded flip-flop) you do need to add the clip twice, once for getting the proper rotation keyed and then to add the clip at that rotation. You add it, and the automatic alignment will get it in the right place. Without changing the timeline, rotate the character into the proper orientation, and then delete and replace the clip. When you delete the clip, it leaves the rotation key in place, so your good to go.
So even wildly disparate clips can be combined this way pretty quickly.
Thanks again 3DTest! :)
So..... The first key, before the end of the first clip is key (sorry). Interestingly, if you place a key by double-clicking in the transform channel, it will not key position. This key can be a floater, and be moved along the timeline without effecting the clip's timing. So put it in and add another key at the end of the clip. Rotate your character on that clip, and then go ahead and add the second clip.
This works on any motion clips, with root tracking enabled or disabled.
mark
mark
Posts: 4.9K, Visits: 16.7K
Simply brilliant 3DTest!!!!:D:D:D
PROMO-BACK2
dogged2003
dogged2003
Posts: 418, Visits: 4.5K
Very necessary: combination of the root position in space (now the Z axis is not considered), and rotation in space. But it is not.
Eeeee. As old as the world of IC. Much attention was paid. From stunt shows. To edit the file "persons".  Maybe in the IC7?
For example RL explained how to do it:
My YouTube channel.
justaviking (2/20/2017)
Nice workaround.
Still waiting for a big reworking of the "locomotion" system by Reallusion.
Yes Indeedy! :)
Posts: 8.2K, Visits: 26.5K
Nice workaround.
