Cary B
Cary B
Visits: 3.8K
WOW! This is fantastic,thanks so much for sharing this, 3DTest! I add my kudos for all your hard work. And thanks for the update, Rampa.
Walt_R
Walt_R
Last Active: 9 Months Ago
Visits: 5.0K
Tried it and it works. Fantastically simple. :D Thank you 3DTest.
CtrlZ
Last Active: 5 days ago
Visits: 4.5K
Game Changer for me Awesome!
Home built liquid cooled AMD Ryzen 7 1800X cpu (8 core 16 thread) 4.0GHz, rtx 3090, ASUS Crosshair VI Hero motherboard, 64 GB RAM, 500 GB SSD (Samsung 850 EVO) 6 TB HD's 4K monitor.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Unbelievable! The solution was under our nose for years :laugh: Thanks a lot for sharing this tutorial !
Cheers
Roberto
Visits: 62.6K
And another follow up.........
When using motions that start out in different directions (the ones that cause the dreaded flip-flop) you do need to add the clip twice, once for getting the proper rotation keyed and then to add the clip at that rotation. You add it, and the automatic alignment will get it in the right place. Without changing the timeline, rotate the character into the proper orientation, and then delete and replace the clip. When you delete the clip, it leaves the rotation key in place, so your good to go.
So even wildly disparate clips can be combined this way pretty quickly.
Thanks again 3DTest! :)
Visits: 62.6K
So..... The first key, before the end of the first clip is key (sorry). Interestingly, if you place a key by double-clicking in the transform channel, it will not key position. This key can be a floater, and be moved along the timeline without effecting the clip's timing. So put it in and add another key at the end of the clip. Rotate your character on that clip, and then go ahead and add the second clip.
This works on any motion clips, with root tracking enabled or disabled.
mark
Posts: 4.9K,
Visits: 16.7K
Simply brilliant 3DTest!!!! :D:D:D
dogged2003
dogged2003
Visits: 4.5K
Very necessary: combination of the root position in space (now the Z axis is not considered), and rotation in space. But it is not. Eeeee. As old as the world of IC. Much attention was paid. From stunt shows. To edit the file "persons". Maybe in the IC7? For example RL explained how to do it:
My YouTube channel.
Visits: 62.6K
justaviking (2/20/2017) Nice workaround.
Still waiting for a big reworking of the "locomotion" system by Reallusion.Yes Indeedy! :)
Nice workaround.
