No Sound in Crazy Talk 8 pro
Posted By curt.larsson 8 Years Ago
curt.larsson
curt.larsson
Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)
Last Active: 8 Years Ago
Posts: 6, Visits: 24
I have had this issue several times, that when I am importing a sound file into Crazy Talk 8 pro, it does not play any sound at all.
But if I play this sound file in any other program, then it plays the sound normally. The computer plays test sound also. The only problem is when this sound file is imported into CrazyTalk 8 pro no sound plays.
I have re-started to computer, but nothing is happening, the same problem.
I noticed that one of the tutorial guys had this problem when i was doing the tutorial, he said the sound disappeared and he didn't know why, then later on in the same tutorial the sound came back again, and he did not know what was happening.
When I tried to load default project, then the sound works, and even my old project. It seems to reset the audio function. However, later it falls back to no sound again. And if I reload default project, and some of my old projects, the sound works.
I imported the audio file to the default project, and the sound worked.
This problem happened to Kai at 37,51 minutes in on his demonstation video "CrazyTalk 8_Easy to create a Talking Avatars_September 7 , 2016"
So Kai had the same problem as I have.
