I would check the audio settings for your recording device to make sure you don't have anything set that could be causing this. You can right click on your system volume control (bottom right of your desktop) and choose
Recording Devices. Then select your device and choose
Properties.
Crazytalk will use the device that is set as default for recording so make sure you have the correct device selected.
One other thing to check is that you have the option selected for "Allow Application To Take Exclusive Control of This Device" under the Advanced tab. This may help.
If you still continue to have problems, please contact support using the link below.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Thanks.
