Recording problems crazy talk
Posted By mmarcoantoni 17 Years Ago
mmarcoantoni
mmarcoantoni
Posted 17 Years Ago
Junior Member (198 reputation)Junior Member (198 reputation)Junior Member (198 reputation)Junior Member (198 reputation)Junior Member (198 reputation)Junior Member (198 reputation)Junior Member (198 reputation)Junior Member (198 reputation)Junior Member (198 reputation)
Last Active: 10 Years Ago
Posts: 1, Visits: 25
Hi, i have a problem, when i try to record a speech into crazy talk 6 using the same volume of my voice during speech, after finished my recording i see that the volume of the recording gradiently gets low is like an auto regulation of the recording or something, the scroll of the volume recording windows is always on top but the result is always the same, even if i finish my speech screamig the volume at the final of the speech is very low almost unperseptive any one can help me?
Thanks...
Posted 17 Years Ago
Posts: 23.1K, Visits: 36.6K
I would check the audio settings for your recording device to make sure you don't have anything set that could be causing this. You can right click on your system volume control (bottom right of your desktop) and choose Recording Devices. Then select your device and choose Properties.
Crazytalk will use the device that is set as default for recording so make sure you have the correct device selected.
One other thing to check is that you have the option selected for "Allow Application To Take Exclusive Control of This Device" under the Advanced tab. This may help.
If you still continue to have problems, please contact support using the link below.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Thanks.
