Lip sinc screen
Posted By bamdelco 18 Years Ago
bamdelco
bamdelco
Posted 18 Years Ago
Veteran Member (524 reputation)Veteran Member (524 reputation)Veteran Member (524 reputation)Veteran Member (524 reputation)Veteran Member (524 reputation)Veteran Member (524 reputation)Veteran Member (524 reputation)Veteran Member (524 reputation)Veteran Member (524 reputation)
Last Active: 13 Years Ago
Posts: 19, Visits: 83
Phil (2/22/2008)
Bam
This might help:
Zoom right into your timeline using the timeline slider
Select Simple from the timeline menu then check lips
This should bring you into a close view of each individual lip movement.
Thanks
Good tip!!!! Thanks a lot !!!!!
Phil_20090922184357260
Posted 18 Years Ago
Senior Member (337 reputation)Senior Member (337 reputation)Senior Member (337 reputation)Senior Member (337 reputation)Senior Member (337 reputation)Senior Member (337 reputation)Senior Member (337 reputation)Senior Member (337 reputation)Senior Member (337 reputation)
Last Active: 18 Years Ago
Posts: 21, Visits: 96
Bam
This might help:
Thanks
bamdelco
bamdelco
Posted 18 Years Ago
I would like to see a better way to edit the lip sync line, perhaps a pop-up screen that gives a bigger picture. Those little itty-bitty phoneme tags against that little itty-bitty wave file, are a bit difficult to sinc up. It's kind of hard on the eyes and patience to be messing with these little icons for hours at a time in front of a computer screen ... it makes for a long day of animation.
Crazy Talk 5 is designed pretty much for the amateur, home user, but it has so many professional and commercial potentialities, than it really needs to address this level a bit more.
