Lip sinc screen
https://forum.reallusion.com/Topic3137.aspx
Print Topic | Close Window
By bamdelco - 18 Years Ago
I would like to see a better way to edit the lip sync line, perhaps a pop-up screen that gives a bigger picture. Those little itty-bitty phoneme tags against that little itty-bitty wave file, are a bit difficult to sinc up. It's kind of hard on the eyes and patience to be messing with these little icons for hours at a time in front of a computer screen ... it makes for a long day of animation.
Crazy Talk 5 is designed pretty much for the amateur, home user, but it has so many professional and commercial potentialities, than it really needs to address this level a bit more.
By Phil_20090922184357260 - 18 Years Ago
Bam
This might help:
Zoom right into your timeline using the timeline slider
Select Simple from the timeline menu then check lips
This should bring you into a close view of each individual lip movement.
Thanks
Phil (2/22/2008)
Bam
This might help:
Thanks
Good tip!!!! Thanks a lot !!!!!
