Pixtim
Pixtim
Last Active: 6 Months Ago
Visits: 10.7K
For information, I have re-edited all the animations so that they are now in an appropriate folder. Now you will find this hierarchy: Motion (general) -> Pixrtim_motion-> Watermotions
If you want to take advantage of it, you can clear your purchases and load them again.
I also retouched the hook point of the breaststroke so that it could match the new diving animation.
Pixtim
Pixtim
Visits: 10.7K
Simple dive is now aivalable ! Marketplace
Pixtim
Pixtim
Visits: 10.7K
 "Swimming_underwater_01" is now available ! MarketPlace Have a nice swim !
Ogier
Walt_R
Walt_R
Last Active: 9 Months Ago
Visits: 5.0K
Ogier,
Thank you for getting back to me. More options in animation for iClone users is always a good thing. Good luck and good sales to you also. :)
Walter
Pixtim
Pixtim
Visits: 10.7K
Walter, it's absolutely normal.
In the final package, I will have much less animation than you. I still have two cycle ready to be integrated (underwater and butterfly) and then some objects and clothes related to swimming. The two packages will therefore be quite different.
Good day and good sales!
Ogier
Walt_R
Walt_R
Visits: 5.0K
https://reallusion.com/ContentStore/ccdproduct.aspx?contentid=AIC500CIENU030120120914001Ogier, Above is the link. Thank you for your consideration in looking at it. I appreciate your time and effort. Respectfully, Walter Content Designer of the SWIM Pack in the Content Store
Pixtim
Pixtim
Visits: 10.7K
I had to work on a project and I sought to buy swim packs. Indeed, I saw some animations, but I found nothing precise enough in the movement. In what I saw, the bust and hips were not really animated ... That's why I built these animations myself ... In any case, if you have the link of this pack, I will be happy to see it because it could avoid that I build something too equivalent. Thank you in advance! Ogier
Walt_R
Walt_R
Visits: 5.0K
FYI: There has been a SWIM motions pack in the Content Store since 2012 that works with G3, G5 and G6 (CC) characters.
Pixtim
Pixtim
Visits: 10.7K
thank you for your messages! It's really great fun!
For example video, I confess that I did not use Iclone. I am not yet quite comfortable and quick for everything that is staged and rendering settings. (I work with C4D for almost 15 years and with Iclone since just a year .. then I do not have the same capacity!) ... The renderings were therefore done with Cinema 4D and particles with X-particles (plug-in for C4D). All with a little post-production under After Effect.
Merci pour vos messages! cela fait vraiment super plaisir !
Pour les vidéo d'exemple, j'avoue que je n'ai pas utilisé Iclone. Je ne suis pas encore assez à l'aise et rapide pour tout ce qui est mise en scène et paramètres de rendu. (je travaille avec C4D depuis presque 15 ans et avec Iclone depuis juste une année.. alors je n'ai pas la même capacité!)... Les rendus ont donc été fait sous Cinema 4D et les particules avec X-particules (plug-in pour C4D). Le tout avec un peu de post-production sous After Effect.
Sinon, je ne l'ai pas encore fait mais il faut que j'aille faire un coucou dans le forum français, un des modérateur m'a dit qu'il y avait pas mal de frenchies dans le coin, et là au moins.. je ne bataillerai pas avec google translate ! :)
Ogier
CtrlZ
Visits: 4.5K
Well done!
Home built liquid cooled AMD Ryzen 7 1800X cpu (8 core 16 thread) 4.0GHz, rtx 3090, ASUS Crosshair VI Hero motherboard, 64 GB RAM, 500 GB SSD (Samsung 850 EVO) 6 TB HD's 4K monitor.
