By Pixtim - 9 Years Ago
 Hello everyone, Here's a first swimming motion. This is a breaststroke loop. Marketplace The crawl, the butterfly swim and the underwater swimming are ready, it only misses the images and video presentation ... Good swim !
Ogier
Hello, I just launched the publication of the animation "swim the crawl." I integrated two animations, one with breathing and one without. As I am not yet expert in how to publish products, I have released in the form of a pack in which you will find the two separate animations. Marketplace
Have a nice swim !
Edit and copy from 30/01/17
 "Swimming_underwater_01" is now available ! MarketPlace Have a nice swim !
Ogier
Edit and copy from22/02/17
Simple dive is now aivalable !
By animagic - 9 Years Ago
These are nice swimming motions! I could learn from them...:unsure:
Thanks for your message Animagic! I had to re-learn to swim to make these animations! For the breaststroke, I was convinced that the arm and leg movements were synchronized ... but in fact ... no! :)
By Snarp Farkle - 9 Years Ago
Very nice work Pixtim, these might come in handy. :)
By Zeronimo - 9 Years Ago
beau travail. Peux t-on savoir quels effets de particules as tu utilisé dans la vidéo ? good work. Can we know what particle effects you used in the video?
By CtrlZ - 9 Years Ago
Well done!
thank you for your messages! It's really great fun!
For example video, I confess that I did not use Iclone. I am not yet quite comfortable and quick for everything that is staged and rendering settings. (I work with C4D for almost 15 years and with Iclone since just a year .. then I do not have the same capacity!) ... The renderings were therefore done with Cinema 4D and particles with X-particles (plug-in for C4D). All with a little post-production under After Effect.
Merci pour vos messages! cela fait vraiment super plaisir !
Pour les vidéo d'exemple, j'avoue que je n'ai pas utilisé Iclone. Je ne suis pas encore assez à l'aise et rapide pour tout ce qui est mise en scène et paramètres de rendu. (je travaille avec C4D depuis presque 15 ans et avec Iclone depuis juste une année.. alors je n'ai pas la même capacité!)... Les rendus ont donc été fait sous Cinema 4D et les particules avec X-particules (plug-in pour C4D). Le tout avec un peu de post-production sous After Effect.
Sinon, je ne l'ai pas encore fait mais il faut que j'aille faire un coucou dans le forum français, un des modérateur m'a dit qu'il y avait pas mal de frenchies dans le coin, et là au moins.. je ne bataillerai pas avec google translate ! :)
Ogier
By Walt_R - 9 Years Ago
FYI: There has been a SWIM motions pack in the Content Store since 2012 that works with G3, G5 and G6 (CC) characters.
I had to work on a project and I sought to buy swim packs. Indeed, I saw some animations, but I found nothing precise enough in the movement. In what I saw, the bust and hips were not really animated ... That's why I built these animations myself ... In any case, if you have the link of this pack, I will be happy to see it because it could avoid that I build something too equivalent. Thank you in advance! Ogier
https://reallusion.com/ContentStore/ccdproduct.aspx?contentid=AIC500CIENU030120120914001
Ogier,
Above is the link. Thank you for your consideration in looking at it. I appreciate your time and effort.
Respectfully, Walter Content Designer of the SWIM Pack in the Content Store
Walter, it's absolutely normal.
In the final package, I will have much less animation than you. I still have two cycle ready to be integrated (underwater and butterfly) and then some objects and clothes related to swimming. The two packages will therefore be quite different.
Good day and good sales!
Ogier
Ogier,
Thank you for getting back to me. More options in animation for iClone users is always a good thing. Good luck and good sales to you also. :)
Walter
Ogier
For information, I have re-edited all the animations so that they are now in an appropriate folder. Now you will find this hierarchy: Motion (general) -> Pixrtim_motion-> Watermotions
If you want to take advantage of it, you can clear your purchases and load them again.
I also retouched the hook point of the breaststroke so that it could match the new diving animation.
