FBX Export Enhancements
Posted By Miranda (RL) 10 Years Ago
Miranda (RL)
Miranda (RL)
Posted 10 Years Ago
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
Select Normal Direction When Exporting FBX
Various 3D softwares have different normal directions.
We added the Normal direction radio buttons so one can very quickly export normals that are compatible with the target software.
https://forum.reallusion.com/uploads/images/052554e2-1d09-4a30-b3a7-7292.png
https://forum.reallusion.com/uploads/images/d1db22a8-9188-4435-ad66-0580.jpg
Normal direction settings of various popular software:
https://forum.reallusion.com/uploads/images/c800dc41-311a-4b42-b3e6-91be.jpg
For more information you can read up on Normals direction in the Polycount_Wiki
Miranda (RL)
Miranda (RL)
Posted 10 Years Ago
Export PBR with PBR Textures
The FBX format does not innately support PBR data, so we took it upon ourselves to also export PBR related textures.
User can then manually plug these textures in a 3D material.
On the flip side, if one strictly follows the CC 2.0 Beta directory structure when including PBR textures, then CC will automatically load the said textures into their appropriate channels.
File Location of PBR Textures
Path structure follows the convention of character filename > mesh name > material name.
Take the body for example: textures will be put under CC > CC_Base_Body > Skin_Body
https://forum.reallusion.com/uploads/images/1ca6b1da-11a1-49e1-8e79-7991.png
Taking the Upper Teeth as an example: textures will be put under CC_Base_Teeth > CC_Base_Teeth > Upper Teeth
https://forum.reallusion.com/uploads/images/23b29242-f7b3-4d21-adf2-bb4b.png
All PBR related textures will be put in a folder aptly named "textures" in the same directory level with the FBX file and FBXkey data file.
Under the said directory structure, every time a FBX file is exported, the PBR textures are consolidated into the same "Textures" folder.
This can cause considerable confusion with repeated usage, therefore we provide the Gather files into a container folder option. (default: checked)
Once this option is checked all the exported FBX file, FBXkey, and textures will be consolidated under a new folder with the same name as the FBX file.
https://forum.reallusion.com/uploads/images/9bf92de9-b400-4b72-bf46-4610.png
For example, exporting files (fbx, fbxkey, and textures) will be directly deposited into the same folder.
Miranda (RL)
Miranda (RL)
Posted 10 Years Ago
Character Creator 2.0 Beta has 2 FBX export related enhancements.
