One-Click Submission to Sketchfab
Posted By Miranda (RL) 9 Years Ago
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
Sketchfab is a community for users to publish, share, and discover 3D models on a web-based platform.
Character Creator 2.0 Beta allows you to directly upload to Sketchfab, making it painlessly easy to share your 3D artwork with the world.
You can upload to Sketchfab from CC 2.0 Beta with the following steps:
  1. Sketchfab Registration and API Token Acquisition
  2. CC 2.0 Beta Sketchfab Uploader Settings
  3. One-Click CC Character Submission for Sketchfab
We welcome you to share your artwork in Reallusion Forum :)
Miranda (RL)
Miranda (RL)
Follow these steps:
1. Register a  Sketchfab account.  Sketchfab membership falls into 3 categories: Basic, Pro, or Business.  Go to Sketchfab Plans and Pricing to find out more and keep in mind the following limitations:
    • Basic: 50 mb limit per upload
    • Pro: 200 mb limit per upload
    • Business: 500 mb limit per upload
2. Login to your Sketchfab member page and go to settings:
3. In the Password & API section, copy the serial number for your API Token.
Miranda (RL)
Miranda (RL)
Uploading to Sketchfab requires FBX export, therefore make sure to have 3DXchange 6 Pipeline installed then follow the setup instructions below:
Click the  icon from the toolbar to expand the window of "Upload to Sketchfab".
[A] Max Texture Size
Select the desired texture resolution.
Note: If you are a Basic member, we recommend using 512x512, anything larger may surpass your 50 mb upload limit.
[B] Include Motion
Check to enable the inclusion of iMotions.
[C] Add Motion Tracks
This button will open a browser for selecting iMotion files.
[D] List of Motion Tracks
Here you can inspect the added motions and change the name of each motion if necessary.
Note: Files with the same names can be added, if one accidentally added a file of the same origin then a warning message will appear.
[E] Delete Motion Clip
Use this to remove individual motion clips.
[F] Load Motion Clip
Use this to replace the current motion clip.
[G] Clear All Tracks
Use this to wipe the entire list of loaded motion clips.
[H] File Information
Here you can give the Sketchfab file a title and description tags.
Note: Add a space multiple tag entries.
[I] Sketchfab Account
Past the Sketchfab API Token here copied from the previous section.
Note: the API Token will be remembered by future sessions of Character Creator.
Miranda (RL)
Miranda (RL)
Once the parameters are set for the uploader and the file has been committed for sending, CC will prompt you to save a copy of your file.
Once decided, the uploader will proceed to package the files and transmit it to Sketchfab (internet connection required).
[J]  Uploading
The packaging and online transmission is in progress when the Upload button is greyed out and changes its title to Uploading.
[K] Hide
Use this to hide the UI while the uploader is packaging and transmitting.
The uploader is done when a message pops up alerting so.  Now you may view the results on the Sketchfab website.
Note: freshly uploaded Sketchfab files are set to Private.  You can make sure the file is okay then set it to Public at your discretion.
Check Online Manual HERE.
We welcome you to share your artwork in the Reallusion Forums :)
Insert > Insert Video > Embed a Sketchfab Video
74% of original size (was 676x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/57a19de1-76ad-4a25-a31e-3ab3.png
