soft cloth issue on skirt after remove object animation
Posted By jlthorne 8 Years Ago
jlthorne
jlthorne
Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)
Posts: 17, Visits: 194
It may be hard to see but Pic 1 is the start (girl in the midde)  Pic 2 move girl left (working)  Pic 3 After using remove object animation on the girl, the skirt becomes disconnected from girl, so when moving her  in any direction the skirt is left behind.  Does anyone know what I am doing wrong?  This is always repeatable.  If I edit and use (undo) until it is past the remove object animation is clicked. The girl and the skirt are reconnected.  Thanks for your help in advance.  Thanks Jeff
.https://forum.reallusion.com/uploads/images/d4965fbb-661a-498a-af86-2f1e.jpg
Distinguished Member (32.6K reputation)Distinguished Member (32.6K reputation)Distinguished Member (32.6K reputation)Distinguished Member (32.6K reputation)Distinguished Member (32.6K reputation)Distinguished Member (32.6K reputation)Distinguished Member (32.6K reputation)Distinguished Member (32.6K reputation)Distinguished Member (32.6K reputation)
Last Active: 35 minutes ago
Posts: 15.7K, Visits: 30.6K
jlthorne (11/19/2016)
Select the skirt and then in the Timeline open the Softcloth track. Delete the clip there, and you should be OK.
The skirt has its own animation track, so remove object animation from the character is not enough.
jlthorne
jlthorne
Thank you so much for your response.  I tried it and it worked.  So much to learn!!!!!
