workhorse
workhorse
Last Active: 7 Years Ago
Visits: 116
workhorse
workhorse
Visits: 116
Trying to render this scene with indigo and im getting this strange pattern on the top of the warehouse roof , can anyone help , I was using a 3d warehouse model embeded into a google earth image . does not show this pattern when rendered in iclone ?
Posts: 5.7K,
Unfortunately this problem occurs quite often with models created in Sketchup and imported into iClone for Indigo rendering. There was a rather detailed discussion on the subject about 18 months ago on the Forum, but I can't find the thread at the moment. The main cause of the problem has to do with the way that faces are created and layered in Sketchup, how these are then triangulated during the conversion in 3DXchange and finally processed by Indigo. The only way to get around this problem is to re-work the model in Sketchup, making sure that no inside faces are reversed and that there are no overlapping faces in the model. Depending on the complexity of the model, this can take quite some time to finish. I've spent up to 8 hours cleaning up a model, but that was much quicker than building it from scratch. Looking at the model in your photo, it would probably be quicker to just build it from scratch.
JimmyB7
JimmyB7
Visits: 3.2K
Check this Realluson YouTube tutorial at about 4:36.
CyberpowerPC, 64 GB Ram, 64bit Windows 10 Pro, Intel Core i9-10980XE 18 Core CPU, ASUS TUF X299 Mark 1 Motherboard, ROG-STRIX-RTX2080TI-O11G-GAMING graphics card, Toshiba 3TB hard drive, 3 x Seagate 3TB hard drives, RAGNAROK 801 Full Tower, LEPA G1600 1600W power supply, Killer WI-FI 6, ASUS PA329Q 32" 4K/UHD IPS Monitor.
workhorse
workhorse
Visits: 116
Thank you very much for the response . It only seems to be a problem from a distance . Thank you very much for your support and fast responses . I really appreciate the help . Have a great day
