Dear All
Welcome to the CrazyTalk Animator 3 Beta test!
Please post your SUGGESTION(s) and RECOMMENDATION(s) here.
If you encounter any BUG(s), please report through FEEDBACK TRACKER.
Feedback Tracker will help you to track the fix status of the bug(s)you reported.
Here are the currently know issues of CTA 3 Beta version, these DO NOT need to be reported.
.Character's expression will be accumulated if record several puppet motion. This can be solved by uncheck "Blend data on next recording
.Fail to export facial animation (.ctFCS) on Bone Base Actor. This can be solved by exporting perform (ctBPerform)
.Hotkey design not completed.
.Z Gizmo for object, not shows correctly.
.Prop replacement behavior in stage being disabled, allow prop replacement in composer only.
.Bone Actor replacement behavior in stage being disabled, allow replacement in composer only.
."Break" and "Mirror" functions in Bone Editor under Composer Mode are temporary disabled.
.Opacity key not works on Image Layer.
.Performance not optimized for image replace in Sprite Editor for Bone Actor.
.Bone and image are possible separate when animate it, if subdivision was set too low in Bone Actor.
.Support Winodws 64 Bit only, not support MAC and Virtual Machine in MAC.
.CTA3 supports 3D motion from iClone 6.52 RLmotion; iClone 6.52 not release yet.
Bug reporting format, please check HERE.
**Howto report bug through Feedback Tracker:
1. Go to Feedback Tracker and click NEW on the up-right corner:
2.Login with Reallusion account:
3.Select CTA 3 Beta:
4.Reporting bug.
For more details, please refer HERE.
8 Years Ago by
Ola(RL)
