Posts: 23.1K,
Visits: 36.6K
simon_fransman (8/10/2016)
Hi! I'm having some difficulties making the CrazyTalk head I'm making looking the same in the iClone Character Creator as it does in CrazyTalk. How do I achieve this? Same problem using both Dynamic Apperance options. It doesn't even remotely match. Example below:   Apart from the lighting differences already mentioned, do also check the page below for more tips on getting an exact likeness. https://forum.reallusion.com/264554/How-to-get-a-exact-likeness-when-bringing-CT-8-head-into-CC
Skuzzlebutt
Skuzzlebutt
Visits: 8.6K
but, bumping up the self illumination will make your avatar immune to lighting and give it a toonie look
simon_fransman
simon_fransman
Last Active: 9 Years Ago
Visits: 32
Mythcons (8/10/2016)
Greetings, The textures are actually the same, it's just that Character Creator is using a different lighting environment and/or a more advanced shader. Since CrazyTalk applies a texture from a photo or image, sometimes this doesn't blender well with the lighting of other 3D shaders. You can dial down the influence of the shader by going to the Materials options and adjusting the 'Self Illumination' channel. At 100%, the shader will have zero influence.  Thank you! That helped
Mythcons
Mythcons
Visits: 3.2K
simon_fransman
simon_fransman
Visits: 32
