Mythcons (8/10/2016)
Greetings,
The textures are actually the same, it's just that Character Creator is using a different lighting environment and/or a more advanced shader. Since CrazyTalk applies a texture from a photo or image, sometimes this doesn't blender well with the lighting of other 3D shaders. You can dial down the influence of the shader by going to the Materials options and adjusting the 'Self Illumination' channel. At 100%, the shader will have zero influence.
Thank you! That helped
