Snarp Farkle
Snarp Farkle
Posted 10 Years Ago
Visits: 3.6K
I'm trying to establish a DAZ/Blender/CC work flow using purchased DAZ clothing items to use and/or modify in Content Creator, but have run across a few issues. Any insight would be greatly appreciated. :)Disregard Issue 1, it became Issue 3.
Snarp Farkle
Snarp Farkle
Posted 10 Years Ago
Visits: 3.6K
Still having issues, thought I had a workaround but this is what I ended up with;
Snarp Farkle
Snarp Farkle
Posted 10 Years Ago
Visits: 3.6K
Miranda (RL) (7/18/2016)
Tips: Transfer skin weights (by rampa) ?Transfer the weights as normal.? Don't delete any groups. Now select your skeleton and set it to pose mode, then select the armor again (it's still in weight paint mode). Cntrl-Click on the head bone to select it. You'll see the weighting like your image showed. In the tools panel, click on "Levels", and set the "Gain" value to zero.  This must be where I am missing a step, I cannot get to this point because I cannot select both the clothing item and the Armature or even see the armature as shown in some of these videos to get to this point. And what is a normal weights transfer, if I follow the steps laid out in the tuts I still end up with the cloth separated from the imported CC fbx.
Galfridus
Galfridus
Posted 10 Years Ago
Visits: 2.2K
@Snarp Farkle The following seems to be working for me..... I`m using Daz 4.9 and dress my Genesis or Genesis 2 before export to .fbx 2012. Everything comes into 3DX6.5 from that .fbx and the pose gets auto corrected. I select the required clothing mesh in 3DX6.5 tree and export via the export mesh command. This produces an .obj file and the textures. I use Blender 2.77a and have set it up using the excellent advice from Rampa in these 2 vids he produced Setting Up Blender For Easier Use :- https://www.youtube.com/watch?v=B7KusxNlXfsBlender Texture Display:- https://www.youtube.com/watch?v=ChtK2CkgdeoI additionally added the RL Base body template before saving the Blender start up file. This means Blender loads ready for me to begin to import the clothing .obj file. Rampa again provided great support in his vid:- Scale Those Blender Clothes https://www.youtube.com/watch?v=Oef-GBcgo18The problem then comes for me in that the vid by Alimayo Arango How To Attach Clothes To A Rigged Character Mesh In Blender 2.73 Does not work for Blender 2.77a However I found the following procedure to follow:- http://stackoverflow.com/questions/34719718/transferring-rig-weights-from-one-mesh-to-another-in-blender-2-76/34760742#34760742This has worked for me with Blender 2.77a I can export an .fbx from blender (remembering to deselect add leaf bones) which will load to continue the create clothes routine over in in CC 1.5. I don`t know how to weight paint yet so the cloth just gets a copy of the body weights. For long robes, tunics etc this is a problem but I added some Soft cloth weight maps ( I can do that) in Iclone to over come this. This may not be the best or even correct way to do this but (despite not really understanding what I am doing) I can make it work. If I load an earlier generation Iclone avatar into 3DX6.5 I can use the same method get clothes from them too. This is important for me as I have considerably more RL Clothing than Daz. Good luck Geoff.
Snarp Farkle
Snarp Farkle
Posted 10 Years Ago
Visits: 3.6K
Thank you Galfridus, I will try your workflow. :)
I picked the robe on purpose knowing it would be harder to do than... say a shirt, my thoughts were if I could do one of the hardest items first the rest would be easy! :crazy: I will move into creating my own assets one day, but for now I just want to learn more by utilizing items I already have, your method looks promising, thanks again for the tip! :)
Posted 10 Years Ago
Visits: 62.6K
Geoff, sending it to 3DX is very clever. No posing in DAZ needed, or anything! :)
Galfridus
Galfridus
Posted 10 Years Ago
Visits: 2.2K
rampa (8/1/2016) Geoff, sending it to 3DX is very clever. No posing in DAZ needed, or anything! :)Thank you Rampa. I owe you a huge debt of gratitude. It`s your tutorials that made it possible for me to even attempt this sort of thing with blender. Using Daz with 3DX6.5 in the initial stages of the work flow was simply a case of me resorting to familiar routines when so much of the following process was so strange and new. Geoff.
Snarp Farkle
Snarp Farkle
Posted 10 Years Ago
Visits: 3.6K
@Galfridus I tried using your method only difference is I am using DAZ 4.8. I went through all the steps but when I come to the end of "using the data transfer modifier" link you provided and this statement; "Lastly, enter object mode > select your piece of clothing and then shift select your rig > CNTRL+P > with empty groups. And wa-lah!"
This is where I keep getting hung up because no matter what key combination I try I cannot select both the clothing item and the rig to continue on with the tuts. I'm obviously missing some thing or lacking an add on, something. I've tried with a skirt too with the same results, I'm at a loss here, very frustrating. :(
Skuzzlebutt
Skuzzlebutt
Posted 10 Years Ago
Visits: 8.6K
Galfridus (8/1/2016) @Snarp Farkle
very cool tip! do you mind if i include that when i update the 3ds max tut to a audio version?
Galfridus
Galfridus
Posted 10 Years Ago
Visits: 2.2K
budbundy (8/2/2016)
very cool tip! do you mind if i include that when i update the 3ds max tut to a audio version? By all means please do Budbundy if you think it will help others. Geoff.
