brand468
brand468
Posted 10 Years Ago
Visits: 7.8K
Can not get alembic animation to work in Octane render? I've managed to import both .obj and .abc file to Octane but can not get any animation. Does anyone have tips on how to do this?
My computer: Intel i7-7700K 4.2Hhz 64Gb, Windows 10, GeForce GTX 1080 + GeForce GTX 1070, Phillips monitor 40" 4K 3840x2160 + 2x28"
wildstar
wildstar
Posted 10 Years Ago
Posts: 1.2K,
Visits: 5.1K
i am using octane render with 3d max plug in for 2016 version and when i import alembic data to 3d max 2016 i lose all uv cordinates, the same dont happen in 2017
brand468
brand468
Posted 10 Years Ago
Visits: 7.8K
.abs file is gray and looks like the first frame of the animation, the .obj file has the texture. I cant find any information about how to set up alembic Octane import from iClone to Octane, has checked tutorial on Hitfilm but it seems that Octane has other settings.?
wendyluvscatz
wendyluvscatz
Posted 10 Years Ago
Posts: 2.5K,
Visits: 19.4K
it may the 250 frame limit I found DAZ studio alembic exporter has I could do a 200 frame batch render but no idea how to load the textures as no nodes DS I load an obj and copy them over I also used an existing DS project I had and swapped out the abc file as had trouble framing it
brand468
brand468
Posted 10 Years Ago
Visits: 7.8K
Hi Wendy, Sorry I do not understand, this is alembic export from iClone to Octane (not from Daz)? ;) Have you tried alembic animation export to Octane?
wendyluvscatz
wendyluvscatz
Posted 10 Years Ago
Posts: 2.5K,
Visits: 19.4K
yes that is from iClone I just used a scene I had previously set up from an old DAZ one in Octane standalone to frame it as so long since I fiddled with it I forgot how to do it as in I used the render target placement nodes etc I had set up previously, dropped the abc file in outliner and connected the cord to the placement brick instead of the DAZ one I had
brand468
brand468
Posted 10 Years Ago
Visits: 7.8K
Ok, then I understand better.:) I have to do some more trials to see if i can get it to work. I hope Reallusion came out with a tutorial later.
Posted 10 Years Ago
Posts: 15.8K,
Visits: 31.4K
Alembic export is point cache, it doesn't include any textures. You have to set that up separately. Depending on the application this can be more or less of a pain but it is doable.
wendyluvscatz
wendyluvscatz
Posted 10 Years Ago
Posts: 2.5K,
Visits: 19.4K
Yes aware but do not know how to add the material zones to do so. Seems missing mtl information As I said a DS import has the little circle nodes on the brick I can link materials to from ones that come in with an obj of the same mesh I then delete.
JimmyB7
JimmyB7
Posted 10 Years Ago
Visits: 3.2K
The link below has iClone to Maya, iClone to Hitfilm, iClone to Fusion Alembic tutorials, etc. May or may not help. I would like to see an Alembic tutorial for Blender too. Link
CyberpowerPC, 64 GB Ram, 64bit Windows 10 Pro, Intel Core i9-10980XE 18 Core CPU, ASUS TUF X299 Mark 1 Motherboard, ROG-STRIX-RTX2080TI-O11G-GAMING graphics card, Toshiba 3TB hard drive, 3 x Seagate 3TB hard drives, RAGNAROK 801 Full Tower, LEPA G1600 1600W power supply, Killer WI-FI 6, ASUS PA329Q 32" 4K/UHD IPS Monitor.
