Posts: 5.7K,
Visits: 26.4K
CC 1.5 slows down to a crawl when making changes to the Materials using the Appearance Editor. Tapani has also reported the problem in this thread. The video below (without audio) demonstrates the problem in real time:
DroneMaster
DroneMaster
Visits: 11.6K
wires (7/15/2016) CC 1.5 slows down to a crawl when making changes to the Materials using the Appearance Editor. I can confim this. And the computer locks out any attempt to get out of the program. Had to use CTL/ALT/Delete to shut down iClone.
https://www.artstation.com/pascalcomics https://www.renderosity.com/users/Pascal_Comics/gallery https://www.deviantart.com/pascalcomics/gallery
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Yes, CC1.5 is veeeery slooooow. I can confirm this Greets from Germany Postfrosch
Tapani
Tapani
Last Active: 7 Years Ago
Visits: 943
Ok, I made an issue to the Appearance Editor, please vote it - hopefully it will help : http://www.reallusion.com/FeedBackTracker/Issue/Appearance-Editor-slider-jamAt this moment, it's quite hard to operate with CC 1.5 Tested a lot : it seems to be when using fe. "Essential clothes / bundle / morphs(?)" even if removed from character. Materials which became with the first installation of CC are adjustable.
"Everything you dream is in your head, give some heat to your heart to improve it"
https://www.youtube.com/user/bluejamribbon
8 Years Ago by
Tapani
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
wendyluvscatz (7/15/2016) Well my first attempt at attaching and weightpainting a simple mesh to an FBX export in Carrara crashed it on re-import so that does not bode well. Not overly concerned though as the essentials cloths coupled with accessories using softbody meet most my needs and can always just import CC iAvatars into 3DX5 as nonstandard too (6 gives me a few issues mostly with facial presets if I fiddle in Carrara with them but also works sort of)I will need to experiment a bit more with it anyway and probably use C8.1 to weightpaint to before exporting from 8.5 as the latter is a right PITA for rigging but needed for import. This was just a first go and not a good example for testing, I will try one with easily shareable assets like Makehuman mesh clothing and hair for that.
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
Oops I meant to quote Rampa, iPad Safari browser does not show very ckearly which post is with which quote button. Or show smileys attachments etc is a pain.
Important Update:Initially we thought a separate discussion thread on issues would be a good way to gather more feedback on any problems you are having. However we now see this is causing some confusion. Because of this I have updated the original post to make it clearer. Please see the change below. Important: If you do find any bugs, issues or glitches in the 1.5 update, please can you first report them in the Feedback Tracker. Then feel free to discuss the issues in this thread. However do make use of the Feedback Tracker first to log the issue.
Apologies for the confusion caused.
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Tapani (7/15/2016)
Ok, I made an issue to the Appearance Editor, please vote it - hopefully it will help : http://www.reallusion.com/FeedBackTracker/Issue/Appearance-Editor-slider-jamAt this moment, it's quite hard to operate with CC 1.5 Tested a lot : it seems to be when using fe. "Essential clothes / bundle / morphs(?)" even if removed from character. Materials which became with the first installation of CC are adjustable. Hi Tapani and others, we are unable to reproduce this issue. Can you help to provide us the settings? See details here: http://www.reallusion.com/FeedBackTracker/Issue/Appearance-Editor-slider-jamThanks!
Tapani
Tapani
Visits: 943
Hi, please check the video by Gerry https://youtu.be/9bMdLKgM4KQHere's one path to follow : 1. Open Character Creator 2. Load a project "Essential_01" 3. Choose "Appearance" tab 4. Click Mini Skirt -> Active Appearance Editor 5. Base Fabrics (black) 6. Adjust using slider "Lightness" - or what ever slider you want Cursor is rolling and moving slowly to the direction you adjusted. It may take 1-2 minutes to move to a place you wanted.
Posts: 5.7K,
Visits: 26.4K
Hi Miranda. Here's a screen shot of my settings:
