Move your libraries to a second drive
Posted By planetstardragon 10 Years Ago
Edward (RL)
Edward (RL)
Posts: 301, Visits: 4.9K
Hi,
Character Creator 4 and iClone 8 (including Cartoon Animator 5) share the same content.
Once you install the first program, the second program will not allow you to choose the content folder.
You may need to reinstall the programs if you want to move the content to another drive.
However, another option is to utilize the Smart Content Manager's multiple drive feature.
Please refer to the tutorial provided below for more information:
Best regards,
Edward
parisgranville
parisgranville
Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)
Posts: 35, Visits: 283
When I installed Iclone, I did not have an option to change the content only the program. Is there a way to add content library from the D: drive?
Posted 10 Years Ago
Posts: 23.1K, Visits: 36.6K
Can I just add a disclaimer for anyone considering diving into the registry to try and change drive or folder locations of their content. If you attempt this you are doing so at your own risk.  Unless you are experienced with registry editing there is a lot that can go wrong and you may end up in a right mess with some or all content failing to show up. My own advise would be to uninstall and perform a clean install choosing the new drive and folder locations. It only takes a few minutes and will avoid any unnecessary risk.
kenmatthews
kenmatthews
Posted 10 Years Ago
Posts: 399, Visits: 1.7K
Hello,
I used Symmover to move my overlarge files to another drive, it worked well...
Best regards.
Ken
The more I learn, the more I realise, I know nothing!
planetstardragon
planetstardragon
Posted 10 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Posts: 11.5K, Visits: 46.0K
agreed,  thank you for posting this :)
"To define Tao is to defile it" - Lao Tzu
Posted 10 Years Ago
Posts: 8.2K, Visits: 26.5K
wires (7/12/2016)
I've added this to the Feedback Tracker - issue 561.
Thanks.  :)
(I would have done it myself, but I can't logon to Feedback Tracker at the office.  The "Login" button (and some others) don't work right.  Our wonderful security software is blocking something.  For the record, I'm taking my lunch break now.)
As for editing the registry and using links and stuff like that... It's great to have workarounds, but they shouldn't be necessary, especially since it's been a topic of conversation for several releases.  It's not a huge deal, but it's silly that it still exists, and it should be relatively easy to address.  Thanks again for entering the issue, Gerry.
Skuzzlebutt
Skuzzlebutt
Posted 10 Years Ago
Posts: 582, Visits: 8.6K
ever consider just moving all the seldom used stuff to a external hd or different location and just making links
to them in the default or custom folders?
it works for many programs, iclone is one of them....................................
Posted 10 Years Ago
Posts: 5.7K, Visits: 26.5K
justaviking (7/12/2016)
planetstardragon (7/12/2016)
This is going to help a ton,   I still don't take back calling it an out-dated system,  because it should be easy enough to change in preferences!
+1
This has been discussed numerous times.  I guess one of us should officially log it in Feedback Tracker.
In addition to the "during installation" options, we should be able to change our storage locations in a Preferences setting, and simply move all our stuff from one drive (or folder) to another.
We should not need to edit the registry.  (But for now, we do.)
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K, Visits: 17.3K
I've moved all my RL files (and many others) to a shared drive on my server. That way I can easily access the files from any computer on my network.
For RL programs the paths are defined in the registry and it is just a matter of finding and changing them for each RL application.
If you are not comfortable editing the registry then the best way is to reinstall each app selecting the new location for your files.
No need to reinstall all your other files in the new location, just copy the old directory to the new location.
I have also successfully moved Steam from a C drive to a D drive for my brother.
Here are instructions from Steam that tell you how to do this:
Moving a Steam Installation and Games
Jeff
Alien Maniac
Alien Maniac
Posted 10 Years Ago
Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)
Posts: 693, Visits: 2.1K
I added all SSD drives.
Now my com is so fast and hardly ever a crash. Well worth the small investment. Just never do a defrag on an SSD. Not necessary and it will mess up your drive using Win 10. Ebay offers great prices on SSD drives. Of course Ram is needed...32GB to work well.
OR
Also, you can uninstall IC and reinstall it without losing anything else. That is the easiest way....but then all NEW materials will be added to your choice of drives for your NEW materials....then just move/copy your current items to that drive according to the proper dir.
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram,  2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor  External data drives total 7 TB. and an AUDIO Studio Recording system.
