Pinpoint on softbody prop
Posted By Roxaszu 10 Years Ago
Roxaszu
Roxaszu
Posted 10 Years Ago
Senior Member (498 reputation)Senior Member (498 reputation)Senior Member (498 reputation)Senior Member (498 reputation)Senior Member (498 reputation)Senior Member (498 reputation)Senior Member (498 reputation)Senior Member (498 reputation)Senior Member (498 reputation)
Last Active: 10 Years Ago
Posts: 4, Visits: 3
Hi Cricky,
How to Identify (by name)the Vertex Pins by using Mesh Select in 3D max ?
Is there any tutorial for it ?
And can it turn to be weight map in iclone 6, But i'm doing it on iclone 5 instead ?
Cricky
Cricky
Posted 10 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
For iClone5:
You need to Identify (by name)the Vertex Pins by using Mesh Select inside 3dsMax and then exporting the propwith those pins identified as the LAST Step before exporting as an FBX.
Once imported through  3dXchange and sent to iClone5, the pins will show up as you identified them by  Vertex Name when choosing "ALT+SHIFT+S"
Without assigning the pins a  name they will not show up in that "ALT+SHIFT+S" panel.
Roxaszu (7/4/2016)
Hi everyone,
I'm new to iclone 5.
And I'm wondering,
I wanna make prop as hair, So I use soft body to make it move smoothly.
but the problem is that when I'm using soft body, The prop will always fall down.
I tried to search on google and they say there's a pin point on iclone 5.
When i try to press Alt+Shift+S, The pinpoint section is empty and can't be attached to any kind of object.
The question is, How can we make that pinpoiint on an object / prop ? (I'm using 3Dmax to make the prop hair.)
Thanks in advance :)
SKYPE ID: rc.650
Roxaszu
Roxaszu
Posted 10 Years Ago
Posts: 4, Visits: 3
Hi everyone,
And I'm wondering,
