MasterMikeDa1
MasterMikeDa1
Posted 10 Years Ago
Visits: 528
I was working with a pack called Old TV Sets. Then I tried the flat screen TV also. No matter what prop I use, it won't let me just drag and drop in video. I have to do it all through the Modify Section's diffuse window. I haven't tried any of the 3d montage or 3D virtual studio to see if they would work. So it seems like I'm the only one having this problem!
MasterMikeDa1
MasterMikeDa1
Posted 10 Years Ago
Visits: 528
Thanks, I'll give that a shot.
RagingKylo
RagingKylo
Posted 10 Years Ago
Last Active: 10 Years Ago
Visits: 457
What kind of prop did you use? 3DFX Virtual Studio?
Posted 10 Years Ago
Posts: 15.8K,
Visits: 31.4K
Mike, I would recommend the advanced pack to be fully covered. It's what I use.
MasterMikeDa1
MasterMikeDa1
Posted 10 Years Ago
Visits: 528
Hello Animagic,
Do you recommend the advanced or standard version of the shark codecs? I am working with windows 7.
Mike
MasterMikeDa1
MasterMikeDa1
Posted 10 Years Ago
Visits: 528
OK, I tried the media player codec pack you supplied. It doe's require that you uninstall any other packs first and reboot, which I did. I have Norton security suite and it didn't alert me to any virus problem. ( I saw The Old Buffers warning before I wrote this.) I don't really know which one is best, and I might just test drive them all to see if there is any difference (Including the one listed by animagic). But so far, I still can't drag and drop directly into a project or props. It's probably a simple setting that needs to be changed or applied. Just need to find out what it is.
Mike
Snarp Farkle
Snarp Farkle
Posted 10 Years Ago
Visits: 3.6K
animagic (6/21/2016)
For a reliable codec pack that I've used since Windows XP, check out here: http://shark007.net/. It installs codecs but also does a cleanup of unreliable codecs installed by other programs, including K-Lite. I had completely forgot about this one animagic, even though the Media Player Codec Pack did solve a problem I had with no sound when using the HDMI port, I liked the shark setup better and will go back to it. Thanks for the heads up animagic! :)
Posted 10 Years Ago
Posts: 15.8K,
Visits: 31.4K
RagingKylo
RagingKylo
Posted 10 Years Ago
Visits: 457
If you use Windows PC, you should know Windows usually mark "freeware" as "malware". It's false alert. Shame on Microsoft. But if you don't trust this pack, just delete it.
TheOldBuffer
TheOldBuffer
Posted 10 Years Ago
Visits: 6.4K
Warning ! ! ! The media player codec pack listed above has a Trojan attached to it.
Homebuilt computer - Windoze 10, INTEL i9 9900 k @ 5.1 GHz, EVGA RTX 2080 TI XC ULTRA, 16GB 3100 MHz RAM, Asus Maximus Hero XI motherboard, Sound blaster Z series. iClone6 & 7 Pipeline, Crazytalk 8, Crazytalk Animator 2, Facefilter, Pop video 3, Hitfilm 4Pro, Cubase 8.5 Pro,
