TheOldBuffer
TheOldBuffer
Posted 10 Years Ago
Visits: 6.4K
This is how to reset your windows in the registry.
You can reset your Lip Editor window back to the default location by editing the registry. WARNING: Editing the Windows Registry is NOT recommended for those unfamiliar with registry editing. Be sure to backup the registry prior to making any changes. If you are unsure please uninstall iClone 6 and perform a clean install instead.
1) Type Regedit in the search box and select it from the list.
2) Goto HKEY_CURRENT_USER\SOFTWARE\Reallusion\iClone\6.0\Dialog Position\:\plugin\ICTimelineUI 3) Locate LipSynchingDlg.ui, then right click it and choose Delete 4) Confirm you wish to delete by clicking Yes. 5) Exit the Registry.
Now start iClone 6 you should find your Lip Editor is back in the default position.
I hope this helps.
Homebuilt computer - Windoze 10, INTEL i9 9900 k @ 5.1 GHz, EVGA RTX 2080 TI XC ULTRA, 16GB 3100 MHz RAM, Asus Maximus Hero XI motherboard, Sound blaster Z series. iClone6 & 7 Pipeline, Crazytalk 8, Crazytalk Animator 2, Facefilter, Pop video 3, Hitfilm 4Pro, Cubase 8.5 Pro,
chris_20150307160451360
Posted 10 Years Ago
Visits: 115
I seem to have found the solution. Dual monitors and saved dialogue window locations .. or something like that :) https://forum.reallusion.com/PrintTopic276610.aspx
Posted 10 Years Ago
Visits: 115
The Motion Puppet, Direct Puppet and Face Puppet dialogue windows do not work/open in my iClone install. I have tried opening them via the Modify panel and via the Animation menu - neither method opens the respective dialogue window. I have tried uninstalling and re-installing iClone - but that has not worked either. Has anyone else experienced this issue before?
