By chris_20150307160451360 - 10 Years Ago
The Motion Puppet, Direct Puppet and Face Puppet dialogue windows do not work/open in my iClone install. I have tried opening them via the Modify panel and via the Animation menu - neither method opens the respective dialogue window. I have tried uninstalling and re-installing iClone - but that has not worked either. Has anyone else experienced this issue before?
I seem to have found the solution. Dual monitors and saved dialogue window locations .. or something like that :)
https://forum.reallusion.com/PrintTopic276610.aspx
By TheOldBuffer - 10 Years Ago
This is how to reset your windows in the registry.
You can reset your Lip Editor window back to the default location by editing the registry. WARNING: Editing the Windows Registry is NOT recommended for those unfamiliar with registry editing. Be sure to backup the registry prior to making any changes. If you are unsure please uninstall iClone 6 and perform a clean install instead.
1) Type Regedit in the search box and select it from the list.
2) Goto HKEY_CURRENT_USER\SOFTWARE\Reallusion\iClone\6.0\Dialog Position\:\plugin\ICTimelineUI 3) Locate LipSynchingDlg.ui, then right click it and choose Delete 4) Confirm you wish to delete by clicking Yes. 5) Exit the Registry.
Now start iClone 6 you should find your Lip Editor is back in the default position.
I hope this helps.
