Can you move an entire animation?
Posted By Jsted 9 Years Ago
Jsted
Jsted
Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)
Posts: 9, Visits: 396
I'm using CrazyTalk Animation 2 Pipeline for Mac.
Is there a way to move an entire animation rather than having to select each transformation point? For instance, I've built a simple car animation that starts at X = -214 and ends at X = -140. I want to drag the entire car animation to have the animation start at X = -194 and end at X = -120. I want to drag the car and have both points update but can't seem to find a way to do it. I tried selecting all of the transformation points but when I drag the car it only updates a single point.
Also, when I use collect clip to export an animation it creates a file but when I drag it on top of an object it doesn't create an animation. I've done this before on my PC - does it not work on a Mac (the same way you can't import a video on Mac)?
Thanks for your help.
