Is there ANY external renderer I can use besides indigo?
Posted By jarretttowe 9 Years Ago
3
jarretttowe
jarretttowe
Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)
Posts: 560, Visits: 3.0K
I'm willing to bake, export, whatever I need to do. I want to render outside of iclone 6 pro. I have 3dxchange 6 pro, cinema 4d r 15, poser pro 11, daz studio 4.8, reality 4.2 for poser and daz, and my wife has the current auto desk educational pack (maya, max).
Is there ANY way to send out my iclone files for external rendering?
Please. Will pay for advice.
jarretttowe
jarretttowe
Can the environment be one piece?
will2power71
will2power71
Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)
Posts: 389, Visits: 2.8K
jarretttowe (5/12/2016)
Jarretttowe,
My best advice to you is to Model your scenes in whatever application you choose to render them in. In your case,  I would suggest that you use Cinema 4D or Blender because you already have C4D, and Blender is available for free. I say this because doing it in Iclone if you're not going to render it in Iclone is cause for a lot of unnecessary headaches of jumping back and forth between animations. If you have a reason to do it in Iclone --it would make sense to complete the scene in the app you're using for the final render, and import only the things that are necessary into Iclone to do whatever animation work you're going to do, and then send only the animation back to your final render application. If at all possible, use low poly objects as proxies to animate with and import/export as little as possible.
Cinema 4D has way too much under the hood to not take advantage of, but if you're doing everything in Iclone, then each time you change something or re-arrange something you're going to have to re-export whatever it is you changed in order for everything to be right when you take it into another application. It is far less time consuming to send FBX animations back and forth than it is to send objects, maps, and lighting. Even better still is that Cinema 4D and Blender offer a far more in depth set of animation tools then you would have in Iclone, so whenever possible you're going to want to take advantage of them. For instance: If I am just using Iclone because of say the Kinect Animation plugin, I could take the animation clips I create out of Iclone into Motionbuilder and massage them till I'm satisfied. I could then bring the FBX animation back into Iclone and save it as a motion clip, or do the same in my home animation application. The less you have to do in Iclone, the faster your pipeline is going to get.
My advice to you is to pick the application you're going to use, export everything you are using in Iclone now that you can, and re-set it up in that application so that it matches. Once that's done --do only the things you need to do in Iclone and export only that. It's a one time headache, but you will be far better off that way. Right off the top of my head, I would use Cinema because like Iclone, you can have your own library of assets that you can re-use more easily and efficiently with C4D's library and Catalog systems --which you can customize completely. You can do a lot with Poser, but the interface is not stellar and in a lot of instances it's counter intuitive. The interface is very much like Poser/DAZ except it's well thought out and functional. A lot of people use Blender, but I was not very keen on their interface and the obscure user controls, but Cycles does make an attractive draw for production. As for Reality, It will give you a very high quality still image, but a lot of people routinely talk about leaving it rendering a single image for 40 hours or more. It's a progressive renderer and not built for speed. DAZ/Iray is easy to get a good render out of, but all of it's other tools for animating leave a lot to be desired but it will more than get the job done if you're only doing a single image.
I am assuming you are talking about an animation project, but my opinion would only change slightly if it came to a still image. I did not mention Maya too much because if you get into using Maya/Motionbuilder/Max/Mudbox then you're going to move into a whole new jungle. Autodesk's products are way cool, but they're not without their detractors like the learning curve and it's easy to get distracted by all the capabilities and integration features. Right now I'm into Maya/Motionbuilder/Mental Ray but I can already see that it's a major learning commitment. Autodesk is top of the line but it demands a lot, too.
Skuzzlebutt
Skuzzlebutt
Posts: 582, Visits: 8.6K
pmaina
pmaina
Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)
Last Active: 6 Years Ago
Posts: 503, Visits: 2.2K
Sorry about your current predicament. iClone is a great environment for rapid content development but the render options are currently just too limited.
I don't have much to add to help solve your immediate need but in terms of future needs, there is a vote going on at Feedback Tracker to get RL to address this, hopefully in version 6.x, by adding a biased renderer plugin for V-RAY RT.
The thread started out as an Octane thread but I soon discovered, on further research, that biased renderers like V-RAY are much better suited for animation. Vote for it here.
davide445
davide445
Posts: 98, Visits: 852
Hi Jarrett,
I'm in your same situation, but with a different objective: want to export from iClone to be able to use Indigo.
iClone is really fast in scene setup, animation setup and vegetation creation, with the usage of a good render will be perfect.
Indigo v4 even if in beta it's x10 faster on mine old gpu, equivalent to a $140 GTX 950.
Current Indigo plugin is really a mess, so want to use C4D both as a bridge and to use his mograph features.
Testing the trip iClone--> 3dxchange --> FBX --> C4D --> Indigo I find works except for some materials mismatch.
Problem is as you want to export a whole scene, will test the suggestion to convert all as a prop.
Posts: 15.8K, Visits: 31.4K
I have two questions:
For the solution involving C4D, which edition would minimally be required?
Does C4D have a better interface to render animation using Indigo?
I just noticed that they have a 30% off sale today for their 30th birthday.
animagic (5/12/2016)
Looking at the product comparison on their web page, it looks like Studio is the version to get.
davide445
davide445
Here you can find a comparison btw the different editions.
I will go for the Broadcast min if you want also to use MoGraph (the most famous C4D feature), otherwise Prime will be ok, the next step being the Studio if you need body dynamics simulation (i.e. soft body), advanced character animation, hair simulation.
The Indigo plugin on the v4.0 beta does have some problems (i.e. did setup pure GPU render only on the first frame, an updated version is on the way), on stable release otherwise is working well.
planetstardragon
planetstardragon
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
after a quick search,  it seems that the .igs file is compatible with other 3D software -  now the extent of the compatibility - I don't know,  and how practical it may be,  being that iclone renders each frame as a new file  for indigo...
This is a file that I found searching the net that apparently reads and converts .igs files.
http://3d-viewers.com/iges-viewer.html
I haven't tried this,  so I can't say it works. I simply had a hunch that somewhere in the indigo file system was something that had open compatibility -  and it appears my hunch was right.
"To define Tao is to defile it" - Lao Tzu
3
