OFFICIAL iClone 6.42 Issues Thread
Posted By Peter (RL) 9 Years Ago
3
4
R2 Studio
R2 Studio
Posts: 59, Visits: 377
My update checker says that Iclone and 3DXchange needs to patch.  I tell it to update, which it does, then when I relaunch Iclone and check I am still on 6.42.2725.1 and it says there is an update 6.42.2728, which I keep installing and it doesn't really stick.  For iClone, I am stuck on 6.42.2725 and after "successfully" installing the update to 6.42.2728 it stills says it needs to update.
For my 3D xChange 6.0 Pipeline Pro: I am currently on 6.42.1522.1 and it says I need to update to 6.42.2723, and just like my iClone, it sucessfully patches, but when I re open the program it is still on 6.42.1522.1 and it says I need to update.  I have tried this with iClone and 3Dxchange numerous times (more than 6 times) and I even tried fully uninstalling and it still says it's constantly needing to update-- I'm sick of trying.  I'll put a ticket.
CaptBebops
CaptBebops
Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)Senior Member (256 reputation)
Posts: 7, Visits: 105
This latest patch to 3DXchange appears to be missing the mfc120u.dll as it reports it missing when one tries to run the program and suggests trying to reinstall.  I uninstalled and then downloaded the latest version and still gives the error.
jann
jann
Posts: 146, Visits: 4.5K
iClone won't start, after the latest patch.:angry:
https://forum.reallusion.com/uploads/images/86caf04c-7757-433f-af42-f9fd.jpg
https://forum.reallusion.com/uploads/images/9e56842b-4aec-4415-8650-51b1.jpg
--- Update 31-03-2016 ---
iClone OK :)
CaptBebops
CaptBebops
Just to follow up mfc120u.dll is installed so it shouldn't throw the error.  Both iClone and Character Creator survived the latest patches but they are 64-bit whereas 3DXchange is 32-bit.  I'm running Windows 10.
Laugh Atlantic
Laugh Atlantic
Senior Member (410 reputation)Senior Member (410 reputation)Senior Member (410 reputation)Senior Member (410 reputation)Senior Member (410 reputation)Senior Member (410 reputation)Senior Member (410 reputation)Senior Member (410 reputation)Senior Member (410 reputation)
Last Active: 4 Months Ago
Posts: 9, Visits: 265
Seem to be getting lots of crashes when opening projects.
IC 6.42.2728.1 - Win 10 . Directx 11.2 - AMD Radeon HD 5700 . Processor    Intel(R) Core(TM) i7 CPU         860  @ 2.80GHz, 2801 Mhz, 4 Core(s)
Agonos
Agonos
Last Active: 6 Years Ago
Posts: 1.1K, Visits: 3.1K
Hi all,
There is a
trick to remove the shortcut "CTRL + 6" ? Because personally, it annoys me radically. Just press the "5" instead of "6" and we are obliged again to extend all the tabs.
Madproff
Madproff
Last Active: 9 Years Ago
Posts: 2, Visits: 42
https://forum.reallusion.com/uploads/images/0f24cda1-04c0-4cee-986b-5db9.jpgHello again
               Seem to have problem with importing mp3 sounds iclone 6.42 computer say's closing program i have try'ed drag and drop from your own folders same applys
Ok  found my problems, this seems to have done the job for me.
Needed to download K-lite 12.0.5,
Update Cineform HD codec
Vorbis.ACM had problem
Rockoloco666
Rockoloco666
Group: Banned Members
Posts: 762, Visits: 2.0K
Hi, the lens slider value doesn't reflect the actual value of the lens, ie one key is at 80mm the next is at 120mm but the value is stuck either at 80mm or 120mm, evdn clicking on the actual key doesn't refresh the value, which makes it kind of hard to make adjustments. It works at first but after some time it just freezes
thanks
Posts: 23.1K, Visits: 36.6K
Feedback Tracker Beta is Now Live
No application is 100% free of issues or bugs, as there is always room to improve. So we have created a place where we can all work together to make your products better by making your suggestions visible to all, having them well-categorized, easy to track and easy to implement.
For this we have decided to allow all users to actively participate in our product improvement and development cycles with help from our brand-new Feedback Tracker platform that will put you in the developer seat, allowing you to suggest, vote, prioritize and track all product issues, findings, and enhancements. Ensuring the most efficient and transparent collaboration with you -- our partners. To find the Feedback Tracker please click HERE.
What can the Feedback Tracker do for you?
** Check reported bugs, saving your time on duplicated reporting.
** Report bugs and suggested feature enhancements.
** Voting priority for feature enhancements and bug fixes.
** View bugs we have successfully reproduced, confirming bug fixes that are on their way.
Service Policy & User Guide
gentledragon
gentledragon
Veteran Member (744 reputation)Veteran Member (744 reputation)Veteran Member (744 reputation)Veteran Member (744 reputation)Veteran Member (744 reputation)Veteran Member (744 reputation)Veteran Member (744 reputation)Veteran Member (744 reputation)Veteran Member (744 reputation)
Posts: 12, Visits: 28
Still having trouble transferring Daz avatars with high poly counts through 3dexchange to IClone 6. I keep getting the out of memory message. Just for the heck of it, I tried opening the FBX file in Maya. It opened with no problem, (I didn't need 3dxchange) the only message was I was using over 300K polys. That's when I discovered, 3Dxchange has a limit of no more than 290K polys allowed. How can Daz run with more polys than iClone, I want that photorealistic look. Is there a way to up the limit in 3Dexchange so I can get my avatars to iClone? Also those that do go, do not have their bones, why is it always necessary to reinstall them again in 3Dexhange?
3
4
