Noob alert - Lighting issues
Posted By yourteacher 8 Years Ago
yourteacher
yourteacher
Senior Member (344 reputation)Senior Member (344 reputation)Senior Member (344 reputation)Senior Member (344 reputation)Senior Member (344 reputation)Senior Member (344 reputation)Senior Member (344 reputation)Senior Member (344 reputation)Senior Member (344 reputation)
Last Active: 7 Years Ago
Posts: 3, Visits: 28
Don't say I didn't warn you (See New Member Thread).
Is there any way to set lighting at the beginning of a scene and to have it stable the whole way through?
The reason I'm asking is: I'm using the Lounge Scene, and I have switched all the lights on at the beginning of my set, but there is a light with a mind of its own that seems to switch itself off and on while filming.  I can't find the little blighter anywhere, so I'm wondering if it's the sun, or some such "natural phenomenon".
Any help will be welcome.
Posts: 5.7K, Visits: 26.4K
The Project has a lot of lighting Key frames.
The scene contains a Colour Effect filter that is Key framed, a HDR setting that is Key framed as well as Key framed changes to the Multiplier settings on both Main Lights. These Key frames are set between frames 699 and 799. There may be a few more that you have to search for if removing those doesn't solve the problem.
In the Timeline make sure to select HDR and Effect under the Project tab and then move the scrubber to frame 699. Click on each Key and delete them.
https://forum.reallusion.com/uploads/images/295a2655-5b3e-4cce-be24-4c84.png
To remove the animation on the 2 Main lights, select each one in turn in the Scene Manager and then click on "Remove Object Animation" in the Animation tab.
https://forum.reallusion.com/uploads/images/147d2be6-4fae-431b-9584-469c.png
That should solve the problem.
